Old 02-12-2007, 09:47 PM   #1
The Rusty Gear
Member#: 62293
2002 Impreza TS
Default Change battery terminal position
I just bought the Motomaster spiral cell bettery for my Impreza. It is Canadian Tire's version of the Optima. Comapring the terminal positions on the top of the battery, the new battery has its terminals closer to the front of the car,and the positive battery cable is too short to reach.
Can the position of these top terminals be changed?
I partially pried off the plastic covering where the terminals are and it almost looks as if there are "mounting spots" to mount terminals in different positions (forward, middle, back)
Thanks,
The Rusty Gear is offline   Reply With Quote
Old 02-12-2007, 09:59 PM   #2
silver2004impreza
Member#: 127878
2004 Impreza 2.5TS
2004 Outback sedan H6
I wouldn't pry the top off the battery, there's lots of nasty acid inside there, but I'm sure you already know about the acid. What I'd do if I were in your situation, is trace the positive battery cable and see where it's attached to other things, like brackets and such. There should be several little plastic things that hold the battery cables in place along their length. Every time I have to replace battery cable ends at work I almost always have to undo some of the plastic clips that hold the battery cables to get enough slack in them to make the cables reach the terminals.
silver2004impreza is offline   Reply With Quote
Old 02-12-2007, 10:00 PM   #3
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Maybe you can make the cable reach, if it's attached to the fender well, by undoing the harnes. I managed to gain enough by doing that to reach the post on mine...
wrxdrvr is offline   Reply With Quote
Old 02-12-2007, 10:03 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You can't move the terminals. They are placed when the battery is manufactured.
To use that battery you need to replace the positive starter cable. Assuming you can get the same stuff in your parts stores as we get down here, you need to find a "universal starter to switch" cable which will have large ring terminals on both ends. You want one that is at least 29-30" long. The replacement cable should be installed in exactly the same manner as the original so it is protected from engine heat and movement.
Old 02-13-2007, 12:12 AM   #5
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
I ran a test fit of the optima combo with terrminals closer to the front... I did not like how the cable was pulled tight. The 30" starter cables were 5 bucks at walmart, but i opted for the right battery.
moogoob is offline   Reply With Quote
Bad battery terminal. P0340 Camshaft position sensor circuit malfunction. Related? RChampion Normally Aspirated Powertrain 1 11-25-2008 09:34 PM
I always have deposits on my positive battery terminal -=C=- Off-Topic 18 09-09-2008 04:29 PM
Whats involved with changing the battery terminals on the wires? PaulRex Electrical & Lighting 4 10-08-2007 08:25 PM
Battery terminal? Revision Mid West Subaru Owners Club Forum -- MWSOC 11 04-29-2002 01:48 PM
Keep those battery terminals clean dudes! PunksWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-18-2002 12:09 PM
