South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 01-18-2007, 04:16 PM   #1
02REX4LIFE
Member#: 98865
2006 Legacy 2.5i
"Now its 06LEGGY4LIFE"
Question Anyone do this mod?
http://www.scoobymods.com/forums/showthread.php?t=1564
If so, what has been the outcome?
If not, what do you think about it?
02REX4LIFE is offline   Reply With Quote
Old 01-18-2007, 04:54 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I've done it on both my WRX & FXT ... it's kinda neat since it makes a small difference, maybe a couple hundred rpm's and like 1psi. Not bad for next to no work.
kastle is offline   Reply With Quote
Old 01-18-2007, 04:58 PM   #3
02REX4LIFE
Member#: 98865
2006 Legacy 2.5i
did u tune for it?
Old 01-18-2007, 05:05 PM   #4
racingfish
Member#: 60976
1969 LGT
FATURBO
what mod is it i cant see it....
racingfish is offline   Reply With Quote
Old 01-18-2007, 05:09 PM   #5
02REX4LIFE
Member#: 98865
2006 Legacy 2.5i
u basically replace the coupling that connects ur factory boost solenoid vacuum hose to the "T" next to ur turbo with a bigger, and less restrictive 3/16" coupling.
Old 01-18-2007, 05:50 PM   #6
racingfish
Member#: 60976
1969 LGT
FATURBO
OHHH i did that in 2003... personally i couldnt really tell the diff. mine came with two of those "T" things... i gave the other to my cousin who used it in his 2004 for a day... he said that his car wasnt running right so he took it out.
Old 01-18-2007, 06:00 PM   #7
Lazaride
Member#: 90336
2004 Forester
Subaru Stars
I have not done it but considered it a while back - after researching I decided it was not worth it for me - but if you are trying to get every bit of edge then it may be worth it for you, check this thread out - there is quite a bit out there about it but nothing real conclusive to me - http://forums.nasioc.com/forums/show...=fitting+boost
Lazaride is offline   Reply With Quote
Old 01-18-2007, 06:17 PM   #8
WgnWheel
Member#: 63605
04 Wrx Wgn TimeAtk
10 Golf TDI, 08 Stang GT
i did it way back when...it did nothing.
WgnWheel is offline   Reply With Quote
Old 01-18-2007, 06:34 PM   #9
racingfish
Member#: 60976
1969 LGT
FATURBO
my cousin said he was detonating with it in.
Old 01-19-2007, 10:40 AM   #10
02REX4LIFE
Member#: 98865
2006 Legacy 2.5i
so i decided i was gonna do it and see wut the hype was all about! my car ran amazing for about the first two pulls in everygear and now it runs like SH**. boost spike! boost Fluctuation! I would NOT recommend this mod at all! and on scooobymods it says nothing about this problem! so i replaced it back with the other coupling and it still runs like crap! boost spike and boost fluctuation! now im lost on what to do! im guessing that the computer picked up that it was changed and then started to run like crap! so im hoping that the comp will pick up that i changed it back and start running better!
im gonna try to change the FBC out for a newer less used but functional FBC and see if that works!
Crossin My Fingers!
Old 01-19-2007, 10:42 AM   #11
02REX4LIFE
Member#: 98865
2006 Legacy 2.5i
its not the "T" thing tho. its the coupling before it that connects one of the hoses to the FBC hose.
But i didnt think of changing the "T". think that will help my prob at all or no?
Old 01-19-2007, 11:22 AM   #12
racingfish
Member#: 60976
1969 LGT
FATURBO
MAh bad i didnt mean the T thing... i ment what u were talkin bout.
Old 01-20-2007, 02:53 AM   #13
YOitsDUCE
Member#: 116120
2006 Subaru WRX STI
i just did it.. =] feels great
YOitsDUCE is offline   Reply With Quote
Old 01-20-2007, 10:47 AM   #14
superblkwrx
Member#: 129395
2006 OBPWRX VF39 E85
333WHP 385WTQ 21PSI SD
Man check your vacume lines and look for something you may have accidently disconnected something while doing this. make sure when you removed the tee from the lines that nothing ripped or anything. This sounds like a vacume leak to me.
Crossin My Fingers!
superblkwrx is offline   Reply With Quote
New Mod!! Never seen anyone do this before... Admission_Regret Interior & Exterior Modification 291 05-19-2012 10:03 PM
Anyone in the PDX area do this mod yet? wrxSTIcy North West Impreza Club Forum -- NWIC 33 10-16-2009 11:41 AM
Anyone do resistor mod & can you help? 4eatFp68 North West Impreza Club Forum -- NWIC 8 08-02-2009 04:29 PM
Anyone do this mod? 02REX4LIFE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 01-18-2007 05:47 PM
