Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 01-18-2007, 06:16 PM   #1
Tylerlan
Member#: 121637
Default 2001 LLBEAN Valve Cover Gasket replacement
I just bought a 2001 LLBEAN. I was told i need the valve cover gaskets replaced. I went to the dealership---huge bill to do that.
They said you have to release lower motor mounts and lift engine to get the coils out to remove the gasket cover?
Anyone confirm or deny this?
Also, if you don't have to remove the mounts, can you just take them off and replace them like most cars?
Any help is appreciated.
Also, do they make a chiltons for the 3.0??
Tylerlan is offline   Reply With Quote
Old 01-19-2007, 09:03 AM   #2
skunkfifty
Member#: 73102
1998 legacy outback
white
no chiltons for the 3.0litre.
the boxer layout makes getting to things like the valve covers difficult, but not impossible. lifting the engine like they say would make it immensely easier, but it may be possible to do the job without doing that. Hard for me to say for sure, when i replaced mine the engine was out of the car for a different reason.
those gaskets are pretty simple to replace, but like i said, the boxer layout is what makes it much more time consuming than "most cars" if you or someone you know are mechanically inclined you could do it yourself. the gaskets themselves are pretty cheap. it's not a hard job, just time consuming.
skunkfifty is offline   Reply With Quote
02 WRX valve cover gasket replacement... 1fastser Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 12-16-2013 06:30 PM
Valve cover gasket replacement, ej20k mutiger93gt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-18-2010 11:16 AM
Valve Cover Gasket Replacement 94'325is Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-27-2008 09:57 PM
Who here has replaced the valve cover gaskets on their 96+ DOHC? MaddMax Legacy Forum 16 05-05-2007 01:42 AM
valve cover gasket replacment biggreen96 Service & Maintenance 0 02-11-2002 08:50 PM
