Welcome to the North American Subaru Impreza Owners Club Saturday May 30, 2015
Old 11-26-2001, 10:02 PM   #1
racerwrx
Member#: 10054
Default jack stand placement??
i've got a '02 WRX and this has been the first car i've owned where a good place to put jack stands wasn't obvious. The manual says nothing, and I haven't found anything in the Service Manuals either. So... when jacking up the car, what's the best place to put the stands?? While on the subject... when using a floor jack, are you still using the factory jack point behind the front wheel, or another position? I took a look at some of the cross members, but they didn't seem solid enough to hold the car.
And a word of caution: I have tried a few places to put the jack stands, but found the stands to actually cause some surface damage with the car off the ground.
Cheers,
Erik
racerwrx is offline   Reply With Quote
Old 11-26-2001, 10:55 PM   #2
NotoriousWRX
Member#: 9026
The jack stands can be placed in the obvious locations; behind the front wheels and in front of the rear wheels.
For a floor jack, there is a location in the front, in the middle of a cross member. It should be easy to see. For the back, i haven't done it myself, but I've seen other people say that you can use the rear diff. If I was to use the rear diff, I would put something between it and the jack, just to protect it some.
NotoriousWRX is offline   Reply With Quote
Old 11-27-2001, 10:45 PM   #3
Rocky WRX
Member#: 9837
2002 White WRX Wagon
7800 ft
Lift and jack locations are shown in Section 1 of the MY02 Impreza service manual, page NT-3 and 4. Basically they recommend the side rails as NotoriousWRX mentioned. It recommends the front crossmember and the rear differential for lifting.
That said, I've placed front jackstands on the fore/aft-going frame pieces on either side of the front crossmember, and they worked fine.
Rocky WRX is offline   Reply With Quote
Old 11-28-2001, 04:50 PM   #4
Bitor1
Member#: 9160
2002 Impreza 2.5RS
Platinum Silver
I have placed circular jack stands in the middle of the "chassis rails" running lenghtwise under the car and they indented the surface? I'll be sure to use the wider "y-type" stands to eliminate any structural damage to the chassis in the future. The side jack points (under the door sills) aren't wide enough although they are probailly the safest points.
Just my .02
Bitor1 is offline   Reply With Quote
Old 11-29-2001, 04:44 PM   #5
racerwrx
Member#: 10054
I guess I'll just have to play with it a bit more... You're right (Rocky WRX) about the service manual bit (I seemed to have missed that page -- doh!) I guess I was just having trouble figuring out how to get my stands in there without damaging the rails. That side sill is just so thin, I didn't want to trust it while I'm under the car. Plus, the side skirt (plastic) is right there, so it looks like it will take some damage in the process too. I guess it's better then damaging the sub-chassis!
I was asking about the jack point (which the service manual suggests the front cross-member) because I've experienced some jack slipiage there. But, that seems to be the right spot.
Thanks for the replies!!
Slickdeal Sears Craftsman 2 1/4 ton Floor jack w/jack stands $27.50 plunk10 Off-Topic 18 02-17-2006 01:11 PM
Is anyone using this jack/jack stands? Any problems with these? nkkilla Newbies & FAQs 8 07-27-2005 06:33 PM
Jack stand and jack for 2005 STi Hye-Teck Newbies & FAQs 11 04-05-2005 10:22 PM
need to borrow a jack and a set of jack stands please. V6TurboTA New England Impreza Club Forum -- NESIC 22 04-29-2004 03:03 PM
Axle stands vs. jack stands vs. axle jacks: I'm going under Titanium Samurai Service & Maintenance 2 12-09-2002 11:11 PM
