Old 01-18-2007, 08:20 PM   #1
LegacyWRX
Member#: 127048
97 Impreza coupe
blue
Default WRX springs/95 leg
Hey, I've got a 95 legacy and I recently bought some struts for the front. At napa they were listed as fitting wrx/impreza/and my generation of legacy. I'm pretty sure it will fit and be fine but I just wanted to double check.
The time has come to get springs and I was just going to get wrx springs because they are more readily available than "legacy" springs. I assume they will fit if the struts will.
Also,,, does anyone know about the quality and ride of Perrin springs? They are only $206 on slowboyracing and Perrin is a name I've heard quiet a bit in the Subaru world. Thanks.
LegacyWRX is offline   Reply With Quote
Old 01-18-2007, 08:56 PM   #2
that one legacy
Member#: 103665
i don't know about the Perrin springs, but i do know that the WRX struts will definitely fit your car. the problem you'll have is if you run aftermarket springs, or even OEM springs from a different Subaru. in that case, you'll have to match your top hats accordingly.
just for reference, i'm running '04 STi shocks, springs, and top hats on my '95 Legacy L wagon, and it bolted in perfectly.
that one legacy is offline   Reply With Quote
Old 01-19-2007, 07:27 PM   #3
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
There's a thread in the FAQ uptop about suspension swapping that makes for some good reading.
Anyway, the rear springs should fit no problem, but the front requires different top hats or you need to modify the stock ones.
Plays_With_toys is offline   Reply With Quote
Old 01-20-2007, 10:13 PM   #4
LegacyWRX
Member#: 127048
97 Impreza coupe
blue
I ended up purchasing a set of whiteline controls. They are a little more than the perrins but the top hats to make the wrx springs fit would've costed close to 300! I've heard nothing but good reviews about the whitelines and I think it was a good purchase. Thanks for the Input!
WRX springs/95 leg LegacyWRX Brakes, Steering & Suspension 2 01-18-2007 10:47 PM
Tranny swap question? 95 leg greenscoobie86 Transmission (AT/MT) & Driveline 3 11-10-2004 10:53 AM
Rochester. NY- 95 Leg. L Wagon subyfanatic Private Vehicle 'For Sale' Classifieds 0 03-14-2004 05:44 PM
ej22t swap into 95 leg... ecu? legacy2003 Pre-2002 Factory Turbo Powertrain 6 10-01-2003 07:37 PM
02 WRX Wagon springs on Leg. Wagon? Subie Gal Legacy Forum 20 02-26-2003 07:19 PM
Message Board Statistics All times are GMT -4. The time now is 12:47 PM.
