Old 01-18-2007, 11:17 PM   #1
roccrew585
Member#: 91840
Default need help with cel number P1518 = starter switch circuit low input
i have these cel reading below.. can someone tell me what causing it and how to fix it.. thanks..
P0137 = 0-2 sensor circuit low voltage.
P0138 = 0-2 sensor circuit high voltage.
P0317 = rough road hardware not present
P0502 = Vehicle speed sensor circuit low input
P0503 = vehicle speed sensor intermittent/ erratic/ HIgh
P0852 = Neutral switch input circuit high
P1152 = 0-2 sensor circuit range/ performance (low)
P1153 = 0-2 sensor circuit range/ performance (high)
roccrew585 is offline   Reply With Quote
Old 01-18-2007, 11:33 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....welll.......for your 87 Yugo that's just fine....no problems at all....
...what kind of crap did ya try to install on what kind and year of car????
jesus christ.....this is MOST annoying......make a damned thread and don't even list the god damned car
Old 01-18-2007, 11:37 PM   #3
roccrew585
Member#: 91840
Sorry i have an 04 STI with these mods listed below.
- HKS Hi-Power Exhaust - FP Green 3 inch inlet turbo
- HKS up-pipe - Walbro 255 fuel pump
- HKS Down-pipe - Sti 816cc (modification)
- HKS Ssqv bov - Perrin Oil Catch Can
- Turboxs FMIC - Apexi AVR boost controller
- Turboxs Utec - 3" agency inlet pipe
- Aem Short air intake - Hks header
- TGV delete
Old 01-19-2007, 12:13 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
- TGV delete
Old 04-11-2007, 11:47 AM   #5
secretpickle
Member#: 145954
I have an '06 WRX with similar mods. Having the same problem.
Headers/Uppipe/TBE/BOV/intake...
I have these codes:
p1152 - Front O2 Sensor Circuit Range / Performance (low)
p1153 - Front O2 Sensor Circuit Range / Performance (high)
p0852 - Neutral Switch input circuit high
p1518 - Starter Switch Circuit low input
I'm assuming something's wrong w/the wiring but I just don't know how to even start diagnosing it.
MAtt
secretpickle is offline   Reply With Quote
Old 03-30-2010, 08:43 PM   #6
wphill3
Member#: 206733
2007 STI
Metalic Gray
I am having a similar issue. Can anyone help please?
I have a 07 sti with these codes (Only an spt intake mod done over 1.5 years ago)
P1518
p0483
p2441
Thanks,
Will
wphill3 is offline   Reply With Quote
Old 05-20-2010, 12:25 PM   #7
fzanetti
Member#: 87418
05 05 Legacy 2.5GT
Garnet Red Pearl
P1518
p0483
p2441
Thanks,
Will
P1518 - Either the ignition or starter may be going...
Did you try to remove the negative cable from the battery and see if they go away?
Flavio Zanetti
Boston, MA
fzanetti is offline   Reply With Quote
Old 09-30-2010, 07:52 AM   #8
fai
Member#: 213854
Exclamation Solution
This must be put in FAQ!
1. From driver seat look under panel. There must be two small green connectors. They are plugged together.
2. Unplug them.
3. Enjoy =)
-- These connectors are for diagnostic purposes and normally must not be connected.
fai is offline   Reply With Quote
Old 08-02-2011, 10:23 PM   #9
RedSpyder
Member#: 220714
2. Unplug them.
3. Enjoy =)
YOU SIR HAVE SAVED MY LIFE! IVe had those codes for over a YEAR NOW!!!! (Being a busy man myself I always said. Ill fix em later... )
DUUUDE I WISH I COULD KISS YOU RIGHT NOW!!!
RedSpyder is offline   Reply With Quote
P1518 Starter switch circuit low input Division By Zero Electrical & Lighting 4 10-11-2007 12:48 AM
****need Help With Cel Codes-please Help************** stito Subaru Conversions 4 07-29-2007 04:55 AM
P1518 Starter switch circuit low input - ***? maddhatteroo7 Service & Maintenance 4 12-22-2005 02:17 AM
Help with P0103 Mass air flow sensor circuit high input kenshiro Engine Management & Tuning 0 08-03-2003 02:15 PM
Need Help with Part Numbers and Getting Parts... Xscreamer Normally Aspirated Powertrain 1 02-26-2001 10:48 AM
