Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 01-19-2007, 12:25 AM   #1
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
Default R&I TMIC inlet hoses
I have a 2006 WRX and I will soon be replacing the inlet hoses with a perrin 3-hose kit. Soon meaning as soon as it stops snowing/raining, dries up, and the temps are above freezing.
Other than being careful with the handling of the I/C, is such an installation a straight-forward event? Do I have to be aware of anything in particular? Torque specs for the hoses and/or TMIC?
Any advice/help would be greatly appreciated.
Old 01-19-2007, 11:41 AM   #2
RayO
Member#: 42329
2002 WRX sedan
You'll find lots of posts on this, but here's my experience putting Perrin hoses on my 2002 TMIC:
The clamp on the recirculating hose is as tough to get off as everyone claims; have an extra and be prepared to cut it off, or consider leaving this hose stock.
The Y-pipe I got required a little trimming on one leg; compare the Perrin to the stock pipe before you take the stock pipe off to check for this.
I cleaned out a little molding flash from the inside of the Y-pipe with an Exacto knife, and I took the time to remove and knife-edge the aluminum inlet elbows.
A little alcohol on the ID of the new Y-pipe will make it easier to get onto the turbo outlet.
RayO is offline   Reply With Quote
Old 01-20-2007, 08:50 AM   #3
Big-E
Member#: 123843
2006 WRX Sedan SGM
Thanks RayO for the info.
I have searched and read more about the hoses themselves and not the actual install as you described - which is exactly what I was looking for.
BTW, you wouldn't happen to know the torque specs for the intercooler bolts?
Call me paranoid, but for a part that costs $$$, and based on my past experience (I don't yet have the manuals) that you do want to torque every last fastener to the factory specs and not "just tighten it".
Thanks again.
hose - stock STI tmic inlet hose Kubek Private 'Wanted' Classifieds 1 10-07-2007 03:18 AM
wtb: stock vf39,tmic,inlet hose bloopsta26 Private 'Wanted' Classifieds 5 08-06-2007 12:40 PM
Just installed ebay tmic, inlet hose, typhoon, got a prob I3oostedScooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 12-11-2005 11:41 PM
WTB- TMIC inlet elbow hose jdubman North West Impreza Club Forum -- NWIC 0 01-20-2005 03:27 PM
TMIC, short ram intake, turbo inlet hose BMRKLR Private 'Wanted' Classifieds 4 09-22-2003 01:43 AM
