Old 01-19-2007, 01:15 AM   #1
chuckywang
Member#: 103654
2013 Sport Limited
Satin White
Default No heat while engine is cold.
My car is a 2002 WRX Wagon.
I always have my heat on external circulation (you know that knob in your car you turn to select circulation from the inside vs. the outside). However, my car only heats up when the engine runs and becomes warm. This is all fine and well for the most part.
As a test, I turned the knob for internal circulation and set the temperature to the highest possible setting. I did this while idle with the engine cold. There was no heat. Any ideas on what the problem might be?
(Sorry, I'm a newb and don't know exact terminology.)
chuckywang is offline   Reply With Quote
Old 01-19-2007, 01:53 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....if this is a joke....what is the punchline
...if this is NOT a joke......O M F G
Old 01-19-2007, 01:59 AM   #3
06grayrex
Member#: 116132
2006 wrx tr Stage II
sgm Jorge tuned -RIP :(
This is because 1- the air in the cabin is still cold so your just recirculating cold air. 2- The engine coolant is pump through the heater core and when the coolant is warm and air blows though the heater core, is when you get warm air. Now while the car is warming, you want turn to recirculate cabin air because you will be taking slightly warmer air (from the cabin) compared to outside the outside air temp back through the heater core and the cabin air will be heated faster. Once you are moving say down the highway you can switch to fresh air and turn off the fan and the air from outside will be forced through the heater core w/o any extra electrical load on the alternator. Hope this helps. If this is a Joke then God help you.
06grayrex is offline   Reply With Quote
Old 01-19-2007, 02:07 AM   #4
06grayrex
Member#: 116132
By chance do you think that cars have an electric heater???????? DO you know anything about heating and cooling? God I hope this isn't a joke.
Old 01-19-2007, 02:42 AM   #5
Sushiplate
Member#: 121055
2005 Impreza WRX
OBP (with custom swirls!)
[quote][By chance do you think that cars have an electric heater???????? DO you know anything about heating and cooling? God I hope this isn't a joke./QUOTE]
I could almost understand this not being a joke. I didn't know that the heat came from the engine until I was about 13 and watched a History channel special on the history of Cadillac. (God, I can't belive I remeber that and not how to divide fractions)
Sushiplate is offline   Reply With Quote
Old 01-19-2007, 03:24 AM   #6
chuckywang
Member#: 103654
2013 Sport Limited
Satin White
*goes into a corner and hides*
Ok, I had no idea how it worked.
Old 01-19-2007, 03:39 AM   #7
06grayrex
Member#: 116132
I appologize if I sounded sarcastic but I know there are some people that post things of this nature just to get a rise out people and screw with them. Sorry......If you have any other questions just ask.
Old 01-19-2007, 09:01 AM   #8
orndog
Member#: 34670
2013 No gears!
Saltine American
Ok ok...
My student worker, who was 18 at the time, didn't know how to release a set of vise grips. True story. Maybe that will make you feel a bit better....
orndog is offline   Reply With Quote
Old 01-19-2007, 09:05 AM   #9
Jakes02
Member#: 129234
2002 Finally stage 2
^^duh, keep squeezing the handles together, lol
Jakes02 is offline   Reply With Quote
Old 01-19-2007, 09:10 AM   #10
rkramer
Member#: 118209
2015 WRX Limitec
some cars ARE coming with electrical heating systems now! (nothing suby makes, yet, at least...)
hybrid... no running engine=no heat, so early hybrids had to run the engine constantly for heat. some newer ones have electrical systems to at least supplement the heating.
Old 01-19-2007, 09:56 AM   #11
littlewhitewagon
Member#: 103068
11 STI sedan
you're kidding right? there is a small release handle on the inside of the pliers...
littlewhitewagon is offline   Reply With Quote
Old 01-19-2007, 10:41 AM   #12
leecea
Member#: 37359
2003 WRX
Actually, not on mine. You just pull the handles apart.
leecea is offline   Reply With Quote
Old 01-19-2007, 04:54 PM   #13
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
um......
crampfan is offline   Reply With Quote
Old 01-19-2007, 05:00 PM   #14
norexyet
Member#: 39149
11 elantra
yea i said elantra
that one went right over your head.
norexyet is online now   Reply With Quote
Old 01-19-2007, 06:15 PM   #15
JTJ 2.5
Member#: 81572
1968 Subaru 360
2000 RS-H6 Race Car
Wow, thanks for the laugh.
JTJ 2.5 is offline   Reply With Quote
Old 01-19-2007, 11:39 PM   #16
Feign
Member#: 68604
06 STi
My buddy's Prius does that. Insta-heat!
Feign is offline   Reply With Quote
Old 01-19-2007, 11:56 PM   #17
George71
Member#: 5157
2005 WRX wagon
The drawback of electrical heating systems is that it's a much less efficent way to heat the cabin. I suppose the cars that do have them only use them for a short time until the coolant temperature is hot enough.
George71 is offline   Reply With Quote
Can't downshift while tranny is cold skyrocket101 Newbies & FAQs 21 12-10-2007 05:57 PM
Buzzing from engine while engine is off and cold.... C.J. Newbies & FAQs 5 02-15-2007 09:08 PM
Wierd noise while motor is cold ninjaboy76 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 03-11-2006 01:23 AM
having problems low boost, funny gas smell, no heat while standing still turbocolin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-27-2005 10:32 PM
Tranny fluid-change while car is cold or warm? HomerJay Service & Maintenance 2 06-04-2002 07:07 PM
