Old 01-19-2007, 01:34 AM   #1
humbleRex
Member#: 118454
2006 WRX
WR Blue
Default tires for 17*7.5 +42
its a pcd 100+114.3. i will be lowering with espelir or s tech springs. so what is the max size i can go without rubbing? i have no idea what all these offset is about
humbleRex is offline   Reply With Quote
Old 01-19-2007, 07:00 AM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
You obviously don't know what offset is all about, because +42 on a 17x7.5 is too low for a Subie. +48 would be more like it. If you keep those wheels, I'd say a 225/45-17 is the most you'd get away with, but you may have to run a 215/45-17.
Old 01-19-2007, 07:02 AM   #3
mav1c
Hoodbridge!
Member#: 560
Oh yeah, try this too:
Old 01-19-2007, 03:41 PM   #4
humbleRex
Member#: 118454
2006 WRX
WR Blue
too low as in? i bought 225/45/17 and using it now. any possible effects?
Old 01-19-2007, 03:54 PM   #5
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....too low as in you'll likely have clearance issues. With the +42, you have a surplus of space inboard (i.e. between the strut and tire) but limited space outboard (between the fender and tire). That's why Mav mentioned that a +48 wheel in that width would be more suitable for your car.
.....and you may also want to add "springs" to your search before pulling the trigger on a set.
Kean is offline   Reply With Quote
Old 01-19-2007, 09:31 PM   #6
humbleRex
Member#: 118454
2006 WRX
WR Blue
+48 offset is in terms of the width of the wheel? i have no rubbing issue now and i had ask the mechanic whether or not there will be rubbing issue when lowered, his reply is no
Old 01-19-2007, 10:18 PM   #7
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
the width of the wheel is the 7.5. the offset is the distance from its hub mounting surface to the centerline of the wheel (if looking from the front or rear of the car).
http://www.tirerack.com/wheels/tech/...jsp?techid=101
the lower the offset, the closer it is to your fender. If he says it wont then make sure he gaurantees it or he wont charge you.
druxboyz is offline   Reply With Quote
Old 01-19-2007, 10:38 PM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
....you first need to understand what "offset" is. This link should help:
They also briefly discuss the importance of a "correct" offset (i.e. typically what your OEM wheels would be). Without diving into detail (which has already been discussed at length in several other threads), the goal is to stay as close to the stock offset as possible when moving to a wider wheel. With our cars, this means you want just enough clearance between the tire and the strut. Add too much (like your +42 7.5's) and you will be limited to the tires you can use due to possible rubbing issues with the fender. ......the reverse can also be true which is why Mav mentioned +48 as a more "ideal" offset for that width of wheel. If you currently have those wheels installed on the car, go check for yourself. Compare the room you have both inboard (between the strut and tire) and outboard (between the tire and fender). A +48 offset would bring the whole wheel/tire inward (toward the strut) and give you more "fender room".
EDIT: I was typing a response and had to leave my desk for a few minutes. ......I didn't see your repsonse Drux until I hit "post reply". .....ooops.
Old 01-20-2007, 12:01 AM   #9
humbleRex
Member#: 118454
2006 WRX
WR Blue
with the tires 225/45/17 on now, i realise the gaps is reduced as compared to the stock wheel but not my ideal height. it seems like i cant lower it much (maybe 1.5 finger most?) i want a lowered look (like on tein s tech) and if in my case, what options do i have other than rolling fenders?what is the use for spacers? can they help?
Old 01-20-2007, 03:22 AM   #10
Kean
Member#: 25187
'08 Foz Prem TGM
.....it all depends on the tire and how much space you have. Rolling the fenders may work if you find it's a bit too tight. As for spacers, they will only worsen the problem since the mounting surface will be closer to the centerline of the wheel. In other words, if you add a 5mm spacer to your +42 offset wheels, you will end up with a +37 offset.
btw, with your choice of wheels and your mention of springs such as the S-Techs, you really should be reading the stickys at the top of the forums and put in a little research before making anymore purchases.
Old 01-20-2007, 06:44 AM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...save some $$$ to buy new struts when the slammer springs kill the struts ya got...and save some more $$$ to put real springs on the car when ya tired of the crappy ride ya get outa the junk springs......
Be careful not to crack the paint on the wheel arch when ya roll the fenders...and if ya don't understand why spacers will only make the issue worse.....
STOP.....what ya doin...
...and educate yourself on just exactly what ya doin before ya do something real dumb and waste any more $$$
Old 01-20-2007, 02:01 PM   #12
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
trial and error. we know you're gonna do it anyway, so just do it and let us know you'll be realy close to either having to go 1 notch lower in the tire sizes or having to roll the fenders. Just make sure the tire guy gives you some sort of 'no rubbing' gaurantee.
Old 01-20-2007, 02:16 PM   #13
si12j12
Member#: 99697
04 wrx [wrb]
ni stage-ah san!
what about this..........http://forums.nasioc.com/forums/show....php?t=1172782
i started this thread not too long ago and alot of guys are running very low offsets check it out!
si12j12 is offline   Reply With Quote
Old 01-20-2007, 03:17 PM   #14
jamie_w456
Member#: 114218
jamie_w456 is offline   Reply With Quote
WTB: Tires for 17X8.5 rims HELP neal1st North West Impreza Club Forum -- NWIC 4 04-25-2005 04:36 PM
Need new tires for 17X7.5 Volks kosoku Tire & Wheel 3 03-16-2004 04:03 PM
Which size tires for 17x7.5 SSR Comps? NicGordon Brakes, Steering & Suspension 16 01-14-2003 12:49 PM
What size tires for 17x7.5 SSRs? Kickz107 Brakes, Steering & Suspension 16 11-21-2002 12:19 PM
What size tire for 18x7.5 wheels RDJ8o Brakes, Steering & Suspension 11 03-20-2002 09:36 AM
