Old 01-19-2007, 06:03 AM   #1
totaljudy
Member#: 136212
Default antifreeze
My 2004 impreza outback is using coolant at an absorbant rate. I got the thermostat replaced and the cooling system checked out which seems fine. Could there be a problem with the catalytic converter? It warms up super fast too.Also, can anyone recommend a brand of antifreeze they use other than the official subaru kind?
totaljudy is offline   Reply With Quote
Old 01-19-2007, 06:47 AM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Read the sticky threads Judge Judy, read them....
Old 01-19-2007, 09:07 AM   #3
rkramer
Member#: 118209
2015 WRX Limitec
head gasket...
Old 01-19-2007, 12:51 PM   #4
totaljudy
Member#: 136212
Default why would it be a headgasket?
There's no water in my oil dude.
Old 01-19-2007, 02:18 PM   #5
rkramer
Member#: 118209
2015 WRX Limitec
depends how it is leaking, there doesn't have to be. if the oil passages are intact yet, it could just be coolant leaking into the combustion chamber. it might not be visible in the oil, but it would show up in an oil analysis.
(warming up fast (and overheating) is a sign of head gasket issues)
Old 01-21-2007, 02:16 AM   #6
alfaguy
Member#: 14238
2002 WRX Wagon - PSM
Alfas: 89 Milano | 72 GTV
If it's not leaking externally, and it's not going into the crankcase (oil), then it must be getting into the combustion chamber. It has to go somewhere!
Joe
alfaguy is offline   Reply With Quote
Old 01-21-2007, 10:59 PM   #7
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Please don't call people "dude" they are trying to help you. +1 for head gasket, you've got all the signs except smoke. Prestone and Peak are good, but they are not going to save your engine.
surowrxa is offline   Reply With Quote
overheating and antifreeze all over imprez25 Normally Aspirated Powertrain 30 12-10-2002 08:23 PM
Antifreeze leaking from turbo area Wrxified Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-10-2002 09:12 PM
Antifreeze Woodywayne Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-09-2002 02:03 AM
Pre-Mixed antifreeze/coolant Hozay Service & Maintenance 4 04-08-2002 02:33 PM
seek antifreeze advice rhhnx Technical Forum Archive 1 09-24-2000 01:10 PM
