Old 01-19-2007, 12:57 PM   #1
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
Default what does this do?
well im bored at work, an on page 42 of 44 on ebay i came across this
http://cgi.ebay.com/ebaymotors/New-B...QQcmdZViewItem
i was wonderin what this does exactly? are these the hoses that go to/from the factory boost control? how does changin these make a difference in boost? i understand that by having a bigger hose the vacuum/pressure moves faster, but would this make more boost too?
romanlynch is offline   Reply With Quote
Old 01-19-2007, 01:17 PM   #2
tasq
Member#: 62362
2005 wrx
CGM
tasq is offline   Reply With Quote
Old 01-19-2007, 01:21 PM   #3
boozy04
Member#: 87034
08 Stg2 9.5's 275s
SSM
from what i see it just makes the restriction in your boost lines smaller therefore creating more boost. horrible idea.
boozy04 is offline   Reply With Quote
Old 01-19-2007, 01:23 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Run....run fast. I will make a difference in boost for a week or so before the ECU learns around it and you get really crappy boost.
Listen here: THERE ARE NO GHETTO SHORTCUTS IN SUBARUS. This ain't your cousin Jimmy's DSM, "free mods" and $10 mods don't work on our cars.
Old 01-19-2007, 04:02 PM   #5
elsanto
Member#: 34832
1989 M3
Right.. BUT i do believe this is essentially a pill that will go between your wastegate and bost solenoid. reducing the inner diameter of the hose at the coupling adjusts how boost responds. Shiv used to (and may still) install these on on wrx's with stock boost solenoids.
elsanto is offline   Reply With Quote
Old 01-19-2007, 04:12 PM   #6
turd_ferguson
Member#: 114609
From my experience, something like this will cause over-boosting - especially in the lower revs. Your ecu will then retard the timing, negating any performance you'd get with the higher boost pressure. It might work if you were tuned for it though.
turd_ferguson is offline   Reply With Quote
Old 01-19-2007, 04:46 PM   #7
wrxzboost
Member#: 86322
lol...
wrxzboost is offline   Reply With Quote
Old 01-19-2007, 04:52 PM   #8
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
I'll bet this is the same guy selling 18mm spark plug antifoulers, as a cat code CEL fix. (yes it works, been doing it for years, just not smart enough to sell a $1.26 part for $15.00)
crampfan is offline   Reply With Quote
What does this do?!?!?!? 08SubieWRX General Community 4 11-25-2008 07:50 AM
What does this do? Frogsthatmoo Legacy Forum 10 10-28-2008 03:10 AM
what does this do and how can i use it sigma pi Off-Topic 14 08-11-2003 01:30 AM
So What Does This Do? (radiator ques) stimpy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-26-2003 09:42 AM
What does this do? Keiho Normally Aspirated Powertrain 6 10-30-2000 10:51 PM
