Old 11-27-2001, 12:39 AM   #1
aphex twin
Member#: 10426
Midnight Pearl Black
Question clutch to floor?
i have a 2002 wrx with a stick. its my 2nd car with a stick but i havent driven stick for over 2 years and it was only for a month. i dont know much about the engage point. it seems to be towards the middle for my car. i was wondering if i have to shove the pedal to the floor to shift gears? or can i push it just past the engage point and do it that way? i dont want to damage it, so im asking to be safe. also, i cant seem to get that "smooth" shift...i get this tiny jolt when i release the clutch. i dont dump it...i do it gently and i was wondering if thats something im doing wrong too. thanks for any help guys.
aphex twin is offline   Reply With Quote
Old 11-27-2001, 12:59 AM   #2
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Push that clutch to the floor. Every time! In fact sometimes twice if you want to try double clutching.
You'll get better at smooth shifts with time and practice. It helps to give a tiny amount of throttle as you let the clutch pedal up so the engine speed is what it needs to be in the new gear.
And don't "dump" the clutch unless you absolutely have to. It's hard on the driveline, especially on AWD cars.
Alan is offline   Reply With Quote
Old 12-01-2001, 03:11 AM   #3
jhonas
Member#: 9015
2002 Impreza 2.5RS
Platinum Silver Metallic
To make you feel better, the clutches in these cars tend to grab pretty well (is grab the right word? oh well), resulting in the jerkyness. You'll adapt and be able to shift smoothly with time.
jhonas is offline   Reply With Quote
Old 12-04-2001, 08:43 PM   #4
subiscum
Member#: 11373
2002 wrecked wrx
wrc blue w/ gravel marks
Post me new on here....
ello,
I just got me wrx 1300 miles ago (n its me 1st straight drive mind ye) but I don't push the clutch all the way to the floor, i push it bout an inch. Yet the shift is not jerky atol.... xcept when i don't do it right... being this is me 1st strait drive...... jest food fer thought
subiscum is offline   Reply With Quote
Old 12-23-2001, 11:16 PM   #5
XazerpmiX
Member#: 8605
2001 2.5 RS Coupe
If you can match your revs good enough you only need to touch the clutch when you 1st start from a stop
Mike
XazerpmiX is offline   Reply With Quote
Clutch to floor and grind in 4th graphicsman Transmission (AT/MT) & Driveline 8 08-05-2010 10:40 AM
Clutch stuck to floor once, now slipping Morphirex Transmission (AT/MT) & Driveline 5 10-27-2004 05:22 PM
Clutch stuck to floor- dead clutch or cylinder? JonR Transmission (AT/MT) & Driveline 3 12-19-2003 08:07 PM
Drove through water and clutch sticks to floor ascott Transmission (AT/MT) & Driveline 7 06-18-2003 02:03 PM
Clutch stuck to floor Greenracer6 Transmission (AT/MT) & Driveline 11 10-04-2002 12:41 AM
