#1 |
Member#: 137412
NESIC
Vehicle:2007 Sti Stg 1 |
looking for options (if any) to beef up my 5spd in my 05 wrx?? any options for me, hardend main shaft assemby's???? anything like that
#2 |
Member#: 117391
NESIC
Vehicle:2002 wagon wrb,rock chips,dead bugs |
I'm in the same boat and decided to rebuild using the STI V6 RA cryo'ed gears. Wider and the ratios are more agressive to keep your car on boost for optimal performance.
#3 |
Member#: 77810
Vehicle:2006 Evo IX SE Tarmac Black |
#4 |
Member#: 39149
Vehicle:11 elantra yea i said elantra |
What type of power are you going for?? You can do cyro ra gears, ppg 1-2, ra 3-4-5, ppg 1-4. So many options out there. PPG has billet shift forks, i am pretty sure they have hardened shafts that come with the new gears.
#5 | |
Member#: 117391
NESIC
PPG-4S5T PPG 4 Gear Subaru 5MT Synchro Gear Kit $3450 PPG-5D5T PPG 5 Gear Subaru 5MT Dog Gear Kit $6250 Very nice if you have DEEP pockets.. |
#6 | |
Member#: 137412
NESIC
hmmm dog gears? whats the difference with that and a synchro gear? nevermind looked in my textbook found out Last edited by justpunchit; 01-19-2007 at 02:39 PM. Reason: answered my own question |
#7 | |
Member#: 94494
NWIC
Vehicle:2005 Element 92x Black |
Legacy GT gears is one option The other is RA gears. Legacy GT 1-2's have a bigger tooth/root than the WRX gears, and are similar to the RA's. Nice, cheap option to improve ratios and strength. |
#8 | |
Member#: 117391
NESIC
"What about dog gears, aren't they a lot stronger? Most dog gears use a straight cut (spur) gear design instead of the helical gear profile used by Subaru. Spur gears are actually weaker than helical gears for the same width and tooth pitch. This is because there are fewer teeth meshed at the same time and the curve of the helical profile creates more surface area. However, replacing the synchronizers with dogs allows the manufacturer to significantly widen the gear widths so this loss in strength is reclaimed and then some. We've seen that some of the cheap aftermarket gearsets (dog or synchro) can be actually more prone to failure than an RA set. This is usually a result of insuficient heat treatment or excessively hardening the gears (creating a brittle gear not capable to absorbing high shockloads)." |
#9 | |
Member#: 83294
BAIC
Vehicle:2011 E90 M3 2011 Prius |
#10 | |
Member#: 10831
TXIC
Vehicle:2011 Ferd Ranger 4x4 2009 FXT Stage2 |
would you rather get cheap (R/A gearset) and pay another $2500 when it breaks again? may as well pay the $4500 once and get it over with <--- getting PPG |
#11 |
Member#: 39149
#12 |
Member#: 115420
Vehicle:It's like a STI but it doesn't break= EVO |
Go for PPG. I know its alot of money but you cant put a price on peice of mind. I can drop my clutch as many times as i want and PPG's just smile right back at you. I only drive real aggressive mabye once or twice a month,but it is real nice to know that you wont hear a pop comming from your tranny. Its peice of mind.....thats all it is.
#13 |
Member#: 105115
What is "wrong info" about RAs breaking? They do break. PPG is the only gearset that is strong enough to take REAL abuse.
#14 |
Member#: 39149
There is a member on here going low-mid 11s on ra's with many launches on them and no issues. Not everyone has an extra $3000 to spend on ppg's, even though they are stronger. Ra is a good upgrade for wrx owners, they are very nice to drive and are an affordable upgrade for those that don't have insane power levels (less then 350whp). I will take a 6 speed over ra's and ppg anyday.
I assume you had ra's and are speaking from experience? |
#15 |
Member#: 10831
TXIC
#16 |
Member#: 39149
#17 |
Member#: 10831
TXIC
^^^ well, mine assploded on a dd dyno on a mild 3rd gear pull this weak so it wasn't shock that did it....just mad powah!!111!
#18 | |
Member#: 39149
If you have 5K for ppg's do it. They ARE a better gear, but 95% of people can't just say it is just $5k, no big deal. |
#19 |
Member#: 10831
TXIC
yeah, my tranny has been carp ever since I used launch control at the track one time
(bad idea)there are a few ppl here that have the RAs and have had no problems whatsoever I've been justifying this to my wife so many times lately that I'm sort of on "PPG autopilot" any time this comes up |
#20 | |
Member#: 39149
#21 |
Member#: 115420
How much are RA's? like 1400 or something plus labor.
#22 |
Member#: 10831
TXIC
well, you want to do the synchros too, add another 250
labor is prolly around 900 or so ($2500 all in) |
#23 |
Member#: 39149
it depends most on the shape of the trans that you do it it. If it is blown up then you may have to replace more parts. Or if it is really good shape you may spend less. Anywhere from $2000-$3000 i would say
| Thread Tools | |
| Display Modes | |
| Conc's Build options thread | Concillian | Built Motor Discussion | 4 | 02-16-2010 11:01 PM |
| Build Cost? Build Options? | Tweeder | Built Motor Discussion | 25 | 01-09-2010 08:04 PM |
| EJ257 Build options ... | kato4276 | Built Motor Discussion | 2 | 09-12-2009 06:20 PM |
| IPT race WRX 5spd swap.. Complete 5spd, axles, rear, brakes | Junior2JZ | Tri-State Area Forum | 0 | 10-22-2007 12:19 PM |
| v4 info and build options | kheff46 | Subaru Conversions | 7 | 02-10-2006 09:50 AM |
