Notices
Old 01-19-2007, 04:35 PM   #1
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Default Stuck gas pedal
Hey all,
Something kinda scary happened today...pulled onto a 3 lane boulevard, started to shift to 3rd, mid-way the gas pedal got stuck, and kept going up to the redline...I think it bounced off the limiter once or twice . Anyway, tapped it a couple of times and went back to normal (I was in midshift so it started climbing while I was in neutral). Anyone had this happen? That was the weirdest thing to happen to this car to date (that wasn't my own doing )
I think the gas pedal got stuck under my extra heavy rubber floormats, but just wanted to make sure. You don't think my poor EJ25 will have any problems bouncing off the limiter like that? (funny thing because, I NEVER bounce the rev limiter when I do any event)
I quickly lubed up the pedal cable at the TB right after that just to be sure though...
rougeben83 is offline   Reply With Quote
Old 01-19-2007, 04:40 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
subaru heavy rubber floormats FTL. gf has them and I can't stand them.
fibuz is offline   Reply With Quote
Old 01-19-2007, 05:10 PM   #3
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
I like stock - no problems to date.
Wiscon_Mark is offline   Reply With Quote
Old 01-19-2007, 05:13 PM   #4
rougeben83
Member#: 115154
2005 Outback XT
White on grey
But I'm stock too
Old 01-19-2007, 05:16 PM   #5
andivic
Member#: 7568
how about try taking out Legacy carpet under the rubber mat ?
andivic is offline   Reply With Quote
Old 01-19-2007, 05:54 PM   #6
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Originally Posted by rougeben83 View Post
But I'm stock too
I mean the carpet mats with all the grippers on the bottom - mine does not do that.
Andy is right though, the stock (carpet) floormats are often found underneath the heavy duty rubber mats and is usually culprit.
Old 01-19-2007, 06:06 PM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
lol mark and your one liners
Yeah, I have the stock ones...I guess it's not very smart to run 3 layers of floormats (you read right) First time this has happened to me since I started driving. Weird...
Old 01-19-2007, 06:52 PM   #8
andivic
Member#: 7568
BTW, my clutch pedal sometimes gets stuck by the legacy carpet. I need to figure out a way to make carpet stay instead of keep moving forward !! any bright idea beside using velcro ?
Old 01-19-2007, 07:25 PM   #9
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
I hate floor mats. Over the summer I drive without them. Newer cars have clips that hold them back.
Plays_With_toys is offline   Reply With Quote
Old 01-19-2007, 08:23 PM   #10
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Yeah, my factory one has clips, but the floormat actually ripped it out of the carpet over time...
Old 01-19-2007, 10:30 PM   #11
ivwarrior
Member#: 100610
MBP
Zip-tie it to the seat base? That's the solution I've been considering, but have been too lazy to actually get around to trying.
ivwarrior is offline   Reply With Quote
Old 01-19-2007, 10:35 PM   #12
jedz123
Member#: 67083
1993 Impreza L HB
EJ25D swap, 5-speed FWD
did you check the throttle cable? ....If there is one. Your cable might be getting snared on something near the throttle body. I would pop the hood and have a look see. This has happened to me before but by the time I got to it the car had been bouncing of the rev-limiter(6.5KRPM) for about 30seconds. She still is running fine, ended up my cable was snagged....
hope that helps
Good Luck!
jedz123 is offline   Reply With Quote
Old 01-19-2007, 10:38 PM   #13
jedz123
Member#: 67083
1993 Impreza L HB
I just go without floor mats all together....I hate em'
Old 01-20-2007, 01:08 AM   #14
rougeben83
Member#: 115154
2005 Outback XT
White on grey
hope that helps
Good Luck!
Yup, I checked that too...first thing I checked. It's not snagging anything...it moves pretty freely. I put some lube on the exposed part of the cable, just in case...hmm I guess it was the carpet.
We'll see when I drive 40 miles for an event I have to go tomorrow :crossesfingers:
FS:STi complete gas pedal & clutch/brake pedal covers. joe r Interior/Dressup/Audio & Security 11 12-27-2009 08:08 PM
04 manual shift boot piece. Gas pedal, auto brake pedal and auto shifter assembly scOOtNsOOby Interior/Dressup/Audio & Security 0 10-12-2009 10:05 AM
Gas Pedal stuck ryanv11 Newbies & FAQs 2 06-13-2009 08:21 AM
CT: 07 STi hydro pedal box and DBW gas pedal jamesfacts Interior/Dressup/Audio & Security 16 02-25-2008 02:43 PM
Anybody make a gas pedal (heel/toe friendly) that matches our oe pedals? BIGSKYWRX Interior & Exterior Modification 12 09-09-2003 03:09 PM
