Old 11-27-2001, 01:47 AM   #1
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
Default Ludespeed turbo kit
I just wanted to say that I am very satisfied with Tom's Ludespeed turbo kit. I just installed the stage three kit and everything went together well. I'm still tweeking with it but so far so good. The only trouble I've had is with the turbo to intercooler pipe. It was a bit to long and I had to trim it with a hacksaw, cause it was pushing my intercooler into my firewall. But that was no big deal. I highly recomend the kit to other Impreza owners!
LVSUBARU is offline   Reply With Quote
Old 11-27-2001, 04:09 AM   #2
8Complex
Member#: 922
04 FXT
Red
*nod* My kit has been great as well, for all the times it's been on and off the car (my own stupidity was good at blowing it up often). I've even got my uninstall time down to 4.5 hours.
Old 11-27-2001, 11:48 AM   #3
MINDGAME
Member#: 7500
2002 2.5 TS Wagon
No, it's not a WRX...
Where can I get information on the kit?
MINDGAME is offline   Reply With Quote
Old 11-27-2001, 11:56 AM   #4
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
http://turbo_25rs.tripod.com/
iodine23 is offline   Reply With Quote
Old 11-27-2001, 12:16 PM   #5
MINDGAME
Member#: 7500
2002 2.5 TS Wagon
Thanks for the link. pricing looks great for those parts. Which management system did you opt to use?
Old 11-27-2001, 09:05 PM   #6
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
I'm not running any managment system. With the Ludespeed kit you don't have to. Fuel is managed by a RRFPR.
Old 11-27-2001, 09:14 PM   #7
kaos200
Member#: 2692
just to save you the flames, (or do the honors myself)
you *should* have some sort of engine management with ANY aftermarket turbo or supercharger. You're asking for trouble if you dont compensate and control the engine wisely (rrfpr alone doesnt cut it).
kaos200 is offline   Reply With Quote
Old 11-27-2001, 09:26 PM   #8
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
I'm getting enough fuel. My timing's good. What else would I need to manage? I'm only running 5 psi now, but plan to up It to 7 when I get everything squared away.
Old 11-27-2001, 10:14 PM   #9
kaos200
Member#: 2692
LV, like I said, management *should* be run. By this I mean an actual injector/timing/map controller/value adjuster. You also hadn't mentioned any timing control before in the answer to Mindgame's question.
Old 11-27-2001, 10:23 PM   #10
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
I'm running 9-11psi on the LudeSpeed kit with no management or injectors...of course, I'm sure my setup is a bit different than yours and wouldn;t recomend it
Edit: added the "and wouldn;t recomend it" part
Eric
Eric SS is offline   Reply With Quote
Old 11-27-2001, 11:15 PM   #11
kaos200
Member#: 2692
Eric
Eric your lower compression ej22t has gotten to your head!
Old 11-28-2001, 01:08 AM   #12
Aphex
Member#: 146
'05 Legacy GT
I also have a Ludespeed Kit on a '99, the stage one from the group buy that started it all (same one as 8Complex)
I'd highly recommend Tom as a vendor and the kit itself, Tom continues to help me out with any questions and concerns I have. even after months of the buy being over (believe me, this is something special if you are too new to the board to experience some of the older vendors that have been weeded out)
if he were on ebay he'd be an A+++++++++++++++++++++++++++++++++ seller, heh heh
my kit is the basic stage one, but with a SAAB 900 IC that I have yet to put on, stock clutch holds fairly good, but it's just started slipping when it's really cold out and I get on it hard, but damn at 5psi, you really feel it, it's great.
eli
Aphex is offline   Reply With Quote
Old 11-28-2001, 02:29 AM   #13
ludespeed
Vendor
Member#: 2734
Eric,
what wouldnlt you recommend, the kit itself or running 11psi with no management?
FYI an RRFPR does the job just fine **IF** you are looking to slap a turbo on and drive. If you keep the boost within the suggested range, then it will run a little rich and stay safe. It won't make the MAX power for that level of boost, but it will run hard, stay safe and remain reliable as such. Both the cars that I use as test cars have been running with the RRFPR and a $.12 Zener Diode for months and run great.
Now some poeple want to tune for MAX power. Those people NEED more management. ie J&S, MAP signal modifiers, additional injectors, stand alone ECUs or whatever.
You wanna run 13s with minimal cost? Stick with the RRFPR and boost up to 7psi and you're there.
You wanna run 12's while spending $6k+? Get some good management equipment and run 9+psi and you're there.
Different stroked for different folks.
All depends on cashflow
Tom
ludespeed is offline   Reply With Quote
How 'available' is the Ludespeed turbo kit? bensonwrx Normally Aspirated with bolt-on Forced Induction Powertrain 13 04-08-2002 01:00 PM
LUDESPEED Turbo Kit redmeanie Normally Aspirated with bolt-on Forced Induction Powertrain 5 02-25-2002 05:00 PM
Anybody install a ludespeed turbo kit? agent007kimball Normally Aspirated with bolt-on Forced Induction Powertrain 6 02-06-2002 04:44 PM
Ludespeed Turbo Kit Installed Xscreamer Factory 2.0L Turbo Powertrain 13 05-31-2001 08:30 AM
ludespeed turbo kit info? bttune2.5rs Normally Aspirated Powertrain 12 02-28-2001 06:52 AM
Message Board Statistics All times are GMT -4. The time now is 02:58 AM.
