Old 01-19-2007, 07:14 PM   #1
wrxburton
Member#: 83744
Default How wide a wheel can I run on these
I am thinking of purchasing a set of Super Advans that are 18 by 8.5 with a 45mm offset. They have a set of 225/40/18s on there but I would like to go wider so was wondering what the widest I can go is? Is it possable to run a 255/40/18 or a 255/35/18? I do not want a rubberband as a tire so some sidewall is wanted haha
wrxburton is offline   Reply With Quote
Old 01-19-2007, 07:22 PM   #2
tora
Member#: 5851
09 Forester XT
+ NA Miata
255 or 265/35 no problem.
tora is offline   Reply With Quote
Old 01-19-2007, 07:27 PM   #3
wrxburton
Member#: 83744
you dont think a 265 would rub ? ? Thats what I wanted to run but was worried it would rub
Old 01-19-2007, 08:41 PM   #4
tora
Member#: 5851
09 Forester XT
+ NA Miata
That wasn't your initial question, it was worded that you wanted to know if it would fit on that wheel. I don't know if you have a wagon, a sedan, suspension...there's no way I could determine if it would rub. BUT, a 265 I would think you would get some rubbing on the fender in the back assuming you have a sedan (definitely if you have a wagon). But you could easily roll the fender lip and NOT have rubbage.
Old 01-19-2007, 09:00 PM   #5
wrxburton
Member#: 83744
I figured i would have to roll it. already bought my fender roller and should be doing that as soon as I get it.
my car is an 02 WRX sedan
I am running eibach pro springs, AGX struts. Group N strut tops f/r, Cusco sway bars f/r(hardest setting), Cobb endlinks f/r, cusco rear strut bar -w- v-brace.
Will they fit or will I have to go smaller:-( which i dont want to do
02 wagon... stock wheels. how wide of tire can I go? 03boxer4 Tire & Wheel 4 08-31-2008 10:03 PM
18's on a 04 how wide and low can I go ??? 02WRXer Tire & Wheel 3 05-12-2007 01:59 PM
How much boost can you run on stock fuel? Jake Steed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-25-2002 02:08 AM
How much boost can you run on a stock WRX? Blue_2K2_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 07-09-2002 11:33 PM
how much boost can i run on my EJ22T fourbanger Legacy Forum 7 09-23-2001 05:20 PM
