Old 01-20-2007, 03:16 AM   #1
chaddeus
Member#: 56624
2004 Subaru WRX STi
Default Wheel Alignment Settings
Currently, my car setup is set to
Front: -2
Rear: -1.5
But since I moved to California and I drive a lot of highway, I was thinking to change my alignment to
Front: -1.5
Rear: -1
I am not sure if this change will affect much and if i should keep my current settings OR change to the one that I mentioned aboved OR if you recommend me other settings.
- Charles
chaddeus is offline   Reply With Quote
Old 01-20-2007, 08:35 AM   #2
justpunchit
Member#: 137412
2007 Sti
Stg 1
is your car lowered at all?? im trying to find the specs for like an inch lowering kit my alignment guy cant seem to figure it out on mine and i keep eating the insides of my tires even right after an alignment so i need the specs.
justpunchit is offline   Reply With Quote
Old 01-20-2007, 03:09 PM   #3
infinite012
Member#: 74392
2015 Forester
Now are these camber, toe, or caster numbers?
infinite012 is offline   Reply With Quote
Old 01-20-2007, 05:40 PM   #4
vinceGC8
Member#: 72263
2008 Impreza STi
Dark Grey Metallic
im pretty sure hes referring to camber.
your current settings are fine. a friend was running more than that on his L wagon, daily driver, and the tire wear wasnt bad at all.
i would just leave it as long as ur running 0 toe.
vinceGC8 is offline   Reply With Quote
Old 01-22-2007, 03:42 AM   #5
chaddeus
Member#: 56624
2004 Subaru WRX STi
They are camber. THanks for the advice. I'll keep my alignment.
- Charles
Alignment setting on ALK? Ben Legacy Forum 2 06-04-2001 05:49 AM
ALK alignment setting? Ben Brakes, Steering & Suspension 3 05-22-2001 12:46 AM
Suspension Alignment Settings mykrrrr Brakes, Steering & Suspension 1 03-28-2001 08:03 PM
Whitelines new MY01 - factory alignment settings Jim Gurieff Brakes, Steering & Suspension 3 03-14-2001 03:44 PM
My alignment setting research ... good reference! Joe Lee Brakes, Steering & Suspension 21 03-02-2001 07:15 AM
