Old 01-20-2007, 08:36 AM   #1
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
Default Temp Gauge?
I was driving up in the mountains and my car was at the regular temp (needle was in the middle) but when i started to go down reasonably steep roads, the needle started to drop toward being cold. At one point it went almost all the way to the bottom. I removed the thing under the hood scoop when i blew a headgasket a while back so that i could get some air in the engine bay to help cool when I was stuck in the mountains and had to drive home, could that possibly have any impact? I would guess I was doing about 65 ish when all this happened and the temp outside was close to 30 degrees F. Any ideas?
Thanks
legacy1907 is offline   Reply With Quote
Old 01-20-2007, 01:29 PM   #2
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Sounds like your guages is broken or your Tstat is malfunctioning.
Opening up you scoop would do zilch to cool a running engine - and if the Tstat was working properly, even if it could, this wouldn't happen.
Wiscon_Mark is offline   Reply With Quote
How to modify the stock dummy water temp gauge to real water temp gauge? SuperTurbo Normally Aspirated Powertrain 14 02-01-2008 06:38 PM
Is it possible to use a Water Temp Gauge as Intercooler Temp Gauge ? Sausage Electrical & Lighting 6 12-11-2006 01:35 PM
Temp gauge on cluster... is that oil or engine temp? gopsu Newbies & FAQs 1 10-02-2005 10:45 PM
trying to find air temp gauge. before-after intercooler air temp, and two others STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-10-2003 03:38 PM
Transmission temp gauge idea, Switch to use coolant temp gauge so no dash space taken ciper Transmission (AT/MT) & Driveline 6 06-05-2003 03:54 PM
