Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 01-20-2007, 10:21 AM   #1
da-chaz
Member#: 127256
2006 Impreza 2.5i
SGM
Question SRS Airbag Light stays on during prolonged cold starts.
Hi All. This has been the second time that it has happened to my fully-stock 2.5i 4EAT MY06, 13.5k KMs.
On a cold start, say about 8 hours or more during -4C and colder, the SRS Airbag light comes on during ignition but stays on for the remainder of the drive (upto 1 hour). The quick fix, is to shut the car off about 2-3 minutes later after it's warmed up a bit and to restart it -- at which point the sensor does not light up and we're good to go.
Albeit hardly critical or crucial but this issue seems to be reoccuring now that the temperatures are dropping. Has anyone else had to deal with anything like this?
da-chaz is offline   Reply With Quote
Old 01-22-2007, 08:37 AM   #2
da-chaz
Member#: 127256
2006 Impreza 2.5i
SGM
Sorry for the "bump" but it happened again. I'm guessing it's time to call up the dealership and bring it back to be fixed under warrenty.
Update: So I called up the dealership and booked an appointment for tommorow. Apparently this is a "known" issue that is exclusive to 06 2.5i Imprezas. Subaru of America has yet to formally respond but the dealership wants me to come in for an inspection anyways.
Old 01-30-2008, 10:09 PM   #3
joosrsx
Member#: 81428
2007 WRX Limited
I have the same prob on my 07 WRX. Did the dealership fix the prob?
joosrsx is offline   Reply With Quote
Old 01-31-2008, 06:49 AM   #4
da-chaz
Member#: 127256
2006 Impreza 2.5i
SGM
It seems that whatever they did has fixed the problem. I was told informally it was due to pinched wiring, that only affected the passenger-side airbag. Usually "restarting" will correct the issue.
Now I'm just having trouble turning over when trying to do a cold start in temperatures lower than -10C.
Old 01-31-2008, 01:08 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
There is a TSB that relates to what you both are describing on the 06-07 Impreza. The dealer will have to check it out and see what code it is setting.
SRS light stays on.... how to check what is going on? psyber_0ptix Service & Maintenance 2 04-22-2009 03:13 PM
airbag light stays on jargon Service & Maintenance 3 09-29-2006 07:10 PM
Airbag light stays on WarHawk187 Interior & Exterior Modification 1 07-12-2005 07:40 AM
SRS Airbag light came on. How do I reset? cybin Service & Maintenance 7 12-20-2003 11:40 PM
('93-'01) Airbag light stays on after changing seats gary501 Impreza Forum 8 10-15-2001 07:48 PM
