Old 01-20-2007, 10:37 AM   #1
pieces
Member#: 42964
08 STI, 03OBS, 99L
Default Quick ball joint checking clarification (control arm off).
Checking the ball joint with control arm off-
My manual says, "if you can turn ball joint stud with your fingers, replace ball joint."
My interpretation of this is you should not be able to spin the threaded part (the part in the control arm) and that the large part that goes into the steering knuckle can turn.
Am I reading that right or should the ball joint not turn at all with fingers?
pieces is offline   Reply With Quote
Old 01-20-2007, 11:41 AM   #2
Hayes
Member#: 11808
You should NOT be able to turn the threaded part with your fingers. You read it correctly.
Hayes is offline   Reply With Quote
Old 01-21-2007, 08:56 AM   #3
pieces
Member#: 42964
08 STI, 03OBS, 99L
Cool, thanks for the help.
Got it all put back together and working wonderfully again.
What to do... Tie Rods, Control arms, Ball joints, bump steer, OMG the crazyness!!! Kostamojen Brakes, Steering & Suspension 26 07-25-2006 08:18 AM
Cant get Control Arm Ball Joint off... need help ASAP TROLL Brakes, Steering & Suspension 26 04-01-2006 05:28 PM
WTB: Tie rod, ball joint, strut, wheel, control arm wrxskier18 Private 'Wanted' Classifieds 2 12-11-2005 10:58 AM
FS: TN: Drivers Side Lower Control Arm w/ Ball Joint xEclipsE RaceRx Private 'For Sale' Classifieds 2 03-29-2005 11:07 AM
FS : STi aluminum control arms and ball joints fragment Canada Region Forum 5 01-25-2005 12:25 PM
