Old 01-20-2007, 05:33 PM   #1
SeanB23
Member#: 87309
2002 wrx
Default 235/50/18 fit on 02 sedan???
I was wonderin if anybody has had 235/50/18's on a sedan and if it was fine with no rubbing issues... I want something with a little more meat on the tire I drive on the freeway a lot and my 225/40/18's are loud and not good at all for the mountains....
SeanB23 is offline   Reply With Quote
Old 01-20-2007, 07:22 PM   #2
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
i'd highly NOT recommend that size. that's nearly 10% difference. downsize your wheel.
kennyvb is offline   Reply With Quote
Old 01-21-2007, 09:16 AM   #3
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
No. Way too big in diameter. Try 235/40-18. A little wider and little taller sidewall.
mav1c is online now   Reply With Quote
Old 01-22-2007, 08:47 AM   #4
dc2skel
Member#: 136246
07 WRX 39 swap
555 motorsports tuned
So you are saying that a 235/40-18 has a taller side wall then a 235/50-18? The 40 series has a shorter sidewall then the 50 does. I believe that is what you meant and don't want to flame on you if so. And as far as the 225/40-18 the only difference going to a 235 is the width. Nothing as far as height. Unless of course you jumped up to the 50 series.
dc2skel is offline   Reply With Quote
Old 01-22-2007, 10:03 AM   #5
kennyvb
Member#: 70234
MY86 BMW E30 325
sorry, that's wrong.
Old 01-22-2007, 10:13 AM   #6
mav1c
Hoodbridge!
Member#: 560
I meant a little taller and wider than the 225/40-18. And a 235/40-18 is going top have a taller sidewall than a 225/40-18. Do you know what the "40" means? It's not a static number, it's a percentage of the width. 40% of 235 is going to be more than 40% of 225.
FS (NY): BF Goodrich KDW Tires- 235/50/18, almost new JasonLI25T Wheels/Tires 7 07-26-2009 03:20 PM
235/50 18 ? Would they fit AbACUZ Tire & Wheel 6 05-20-2009 06:39 PM
Kumho ECSTA ASX All Season Radials 235/50/18 $300 NYC Knightmare69 Tri-State Area Private Classifieds 17 03-08-2007 11:27 AM
18X8 Rims w/ 235/50/18 Button Tire & Wheel 0 02-14-2007 02:19 PM
going from 235/40/18 to 235/50/18? looking for trouble? hinduluv Tire & Wheel 10 10-31-2006 12:22 PM
