Old 01-20-2007, 07:39 PM   #1
Kopid
Member#: 30005
2002 WRX sedan
Yellow
Default Timing belt and Power steering belt?
Are timing belt and power steering belt two seperate belts??
My primary purpose of asking this question is because my power steering seems to almost lock up or stop working when i'm reversing out of the parking space and turning at idle.
Furthermore, my car makes that squealing noise during start up in the morning AND while driving.
Seems like this problem is getting worse as times goes by and wanna fix real soon.
So I did a bit of search and figured it could be my pulley and/or timing belt.
I already have bought crank pulley and timing belt.
Would replacing these two peices fix this particular problem?
Thanks in advance.
Kopid is offline   Reply With Quote
Old 01-20-2007, 08:05 PM   #2
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
Timing belt and alternator/power steering belts are two different items
I would do the alternator belt first and check the tensioner. Not sure why you bought a crank pulley...
Old 01-20-2007, 08:15 PM   #3
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
No.
The timing belt is a toothed belt that synchronizes the camshafts to the crankshaft. It's behind the black plastic cover that looks like a dogbone on the front of your engine. You should replace the timing belt at the factory reccomended interval (which is something like 115,000 miles). This is not something to be done by a novice.
The power steering / alternator belt, like the A/C belt is one of the ribbed belts that is exposed in front of the timing belt cover. These are also known as accessory belts.
It is your power steering / alternator belt that needs replacement. While you're in there, replace the A/C belt as well. You will need a metric socket set and an extension to replace the belts. These are very easy to do, good for a novice mechanic. Just make sure not to tighten the new belts too much. If they still squeak, just tighten them a little more. If they still squeak on a cold start (usually after a dew has settled), tighten a little more. Over-tightening can damage the bearings that the idler pulleys (the ones used for adjustment) turn on.
Replacing the crank pulley will require you to lock the engine in place and using a breaker bar and a large socket. It's not hard, but it's also not something for a total novice. You may want to ask for help in your local forum. If there's someone nearby willing to drop by to lend you a hand or at least some advice, you'll be well on your way. Beer/Pizza/etc are always good things to offer in return.
Good luck.
Old 01-20-2007, 11:01 PM   #4
Kopid
Member#: 30005
2002 WRX sedan
Yellow
thank you guru's!!
Awsome details Beaverboy! thanks to you both.
I do not deny the fact that I am a novice and I guess it was my hasty move on buying the timing belt. But still it was recommended by the dealership when I went there for free check-up.
Any advice on where I could purchase the power steering/ alternator belt from?
And do you guys maybe have a link to power steering/ alternator belt replacement instruction?
Old 01-20-2007, 11:07 PM   #5
caesar
Member#: 30745
SRP Greddy(R.I.P)
Bugeye & '99 LandRover D2
Originally Posted by Beaverboy View Post
No.
Good luck.
PERFECT!!!
caesar is offline   Reply With Quote
Old 01-20-2007, 11:09 PM   #6
dibblejr
Member#: 94070
05 LGT
Try subarugenuineparts.com for your belts.
As far as breaking your CP loose, I have never used a breaking method. I made a special long shaft ratchet adapter and I hit the shaft with a mallet and it breaks loose perfect. No sense in hurting yourself trying some of the crazy techniques I have seen posted.
When installing your new CP ensure you have it aligned perfectly on the keyway on the crank shaft, if you are a little off and force it on you will just throw the AL CP in the trash. Hopefully the one you got is just lightened and not UD.
Did you check your PS fluid?
Jay-R
dibblejr is offline   Reply With Quote
Old 01-20-2007, 11:42 PM   #7
Kopid
Member#: 30005
2002 WRX sedan
Yellow
Jay-R
ohhhkay.... so many abbs. lol
I assume that by CP you mean crank pulley? if so, yes I do have Perrin lightend one... which by the way doesn't feel as I light as I imagined it to be. I guess the stock one must be REAL heavy! haha
but what's AL CP and PS fluid?
Old 01-20-2007, 11:53 PM   #8
Evil Dr. Scoob
Member#: 19193
2005 LGT
Regal Blue
You should know that if you replace the crank pulley (or any other pulley) with an underdriven setup, you will likely need different size power steering and alternator belts. The manufacturer should be able to provide the proper size belt.
C
Evil Dr. Scoob is offline   Reply With Quote
Old 01-20-2007, 11:55 PM   #9
ivwarrior
Member#: 100610
MBP
C
Which is just one of the reasons you should get a light-weight pulley, not an under-driven one.
ivwarrior is offline   Reply With Quote
Old 01-21-2007, 01:08 AM   #10
Kopid
Member#: 30005
2002 WRX sedan
Yellow
I do have a light weight pulley
Old 01-21-2007, 01:28 AM   #11
Kopid
Member#: 30005
2002 WRX sedan
Yellow
Jay-R
Could not find the belt from the given site.
Anyone else know where I can find power steering belt?
Old 01-21-2007, 07:54 AM   #12
dibblejr
Member#: 94070
05 LGT
Here's the link to the ALT/PS belt; https://www.subarugenuineparts.com/oe_parts_cat.html
1) go to their site by the link
2) type in vehicle year and make
3) under "Collission Parts"
4) Fill in year, model and make
5) type in "Belt" under "Keyword"
5) enter the 1st part listed will be Alternator belt $17.94
If you PM subiegal (Jamie) here she will help you out. Also you can call her at Chaplins Subaru from the site. You were probably just looking for the PS belt, it is not a single unit belt.
SGP's has probably one of the best shipping times and customer service, so much so I use them and they are 3000 miles away, my Subaru dealer sucks.
AL=Aluminum
CP= Crank Pulley
PS=Power Steering
Fluid=Fluid
Jay-R
Old 01-21-2007, 12:25 PM   #13
ECUboy
Member#: 138360
Timing belt is the one driving the camshafts, you can't see it physically. It's located at the front of the cylinder head covered by a black case.
Power steering belt is visible from the engine bay, it's located at the right side (passenger side) where you can see the belt are driven by the crank pulley.
ECUboy is offline   Reply With Quote
Old 01-21-2007, 12:59 PM   #14
ChristopherG
Member#: 66086
2008 STi
You can probably get the two belts cheaper at Napa/Autozone/Checker.
I work at Napa, so I can provide those part numbers for ya...
A/C - NBH 25-040353
P/S & Alt - NBH 25-050350
Those numbers can probably be crossed at any parts store, too
ChristopherG is offline   Reply With Quote
Old 02-06-2007, 01:13 AM   #15
Kopid
Member#: 30005
2002 WRX sedan
Yellow
ok, had to bump this thread back up because I just could not find an instruction on how to replace PS belt and AC belt.
Searched at scoobymods.com as well but nothing.
Anyone have an instruction?
Old 02-06-2007, 02:08 AM   #16
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
In case you missed his question, it's a good one.
Tightening Power steering belt & AC Belt dans04wrx Brakes, Steering & Suspension 8 01-21-2015 04:01 PM
WTB: drive belt tensioner bolt and power steering pump cap, '98 Impreza rossl Private 'Wanted' Classifieds 0 08-20-2009 11:12 AM
WTB: Alternator and Power Steering Belt Freeman Private 'Wanted' Classifieds 3 03-04-2009 09:49 AM
Air Conditioning and Power Steering belts setzkell Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-29-2008 08:57 PM
need help on power steering belt. masube Legacy Forum 3 11-28-2004 12:21 AM
