Old 01-20-2007, 07:53 PM   #1
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Default P1446? Get rid of it!
Well, since i did my swap, i've had the P1446 code. As you may know, on the USDM models 03+, have the extra vsv for the gastank. I never bothered switching gastanks to remedy this problem.. Thats alot of work for 1 stupid sensor that really doesn't do much.
So finally, i got off my lazy butt and decided to make something up to rid myself of this stupid code. Its easy. Real easy. Should have done it a long time ago. I did it as follows:
1. Obtain old/new vsv, whatever your preference. Any will do, i just happened to grab one at work i had laying around. As long as its a 2 wire vacuum switching valve, it'll do.
2. I have spare wire harnesses both at work and home.. I simply found a connector that plugged into the vsv. Cut it with some extra wire.
3. This applies for my 04 wrx setup. Yours may differ.
Locate ecu connector B84. Pin #23 is the one you need. Its a red/blue wire. If you have there already, cool. If not add it. This is the wire you must add to the ecu, because its ultimately what the ecu will look for as far as something being there. Its the ground side of the vsv.
The power side of the vsv, following the wiring diagram, goes to the ecu also (pin #2 of B84), and supplies power to the other gas tank related vsv's. Although you don't need to worry about it, because its not particular to that 1 vsv. Just find a constant (IG on) power source and hook it up for your power.
4. Find your happy spot to put it.
5. Enjoy the darkness of not having the check engine light shining in your face at night.
Merely a how-to tutorial of how i defeated it.. Your experience may differ. I welcome all posts related, and how you got rid of it.
subbyspeed is offline   Reply With Quote
Old 01-21-2007, 09:42 AM   #2
maddbmxjumper
Member#: 43044
01 sedona red ej20
stage 3 vf23 rs
its about time someone figured this out, im gonna go do mine now. thanks man! kyle
maddbmxjumper is offline   Reply With Quote
Old 01-21-2007, 10:08 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
the other option is to flash it out with openecu
could you use a resistor instead of the vsv
Old 01-21-2007, 11:01 AM   #4
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
i have heard about the resistor thing once.. Do you know what resistor to use for it? Is it like the EGT thing where it has to be a certain resistance?
Old 01-21-2007, 12:20 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
measure the resistance of the vsv...
Old 01-21-2007, 12:30 PM   #6
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
good point.
Old 02-15-2008, 09:37 AM   #7
thrdeye
Member#: 24569
2004 Mazda RX8
Titanium
Can anyone confirm if the connector and Pin numbers for this fix are the same on an 03 ECU?
thrdeye is offline   Reply With Quote
Old 02-18-2008, 04:38 PM   #8
thrdeye
Member#: 24569
2004 Mazda RX8
Titanium
Okay, the 03 and 04 are not the same.
I think I will need to put the wire into B137, Pin 23, which in my 02 harness, has no wire present. I only guess this because PIN 22 is Fuel tank pressure
control solenoid valve, just like the 04
http://www.northursalia.com/modifica...ng/wrxpin.html
Which is the power side of this valve? I guess I'll need to build a harness for it.
Old 08-24-2008, 01:45 PM   #9
PoopRSkupe
Member#: 48886
'00 WRS
'08 Forester XT
i have an 04 wrx swap into my 2000 RS. my P1446 came on only after i went catless and flashed a cobb stg 2 93 map. is the solution the same as the OP's?
PoopRSkupe is offline   Reply With Quote
Old 08-25-2008, 07:20 PM   #10
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
It takes 45 seconds to disable the code with the open source tools. With the code disabled the car will run normal, pass smog and the check engine light comes on whenever something else is wrong.
That said I congratulate your hard work on finding a second solution to this problem
Is this a BOV?! If it is, what do I need to get rid of it? j2los Newbies & FAQs 41 10-27-2006 02:53 AM
Lots of stuff - Need to get rid of it all! Suncoast Autosport Private 'For Sale' Classifieds 10 11-08-2005 10:38 AM
3 pics of my new cf hood, keep it or get rid of it?! 56k maybe sonic03rex Member's Car Gallery 52 06-14-2005 05:18 PM
Do the 2005s get boost creep? If so, how to get rid of it? Optimus Prime Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 09-09-2004 07:13 PM
Remote Keyless "Horn Chirp" Warning. How do i get Rid of it? William WRX Legacy Forum 5 07-26-2000 03:39 PM
