Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 01-20-2007, 09:27 PM   #1
rsotak
Member#: 42432
Default Help cam gears won't rotate!
My timing belt on a WRX jumped a couple of teeth and now the two drivers side cam gear will only rotate about 45o before stopping. Are the vavles bent?
If so can you remove the head with the engine still in or does it need to come out?
Please Help!!!!!!!!!!!!!!!
rsotak is offline   Reply With Quote
Old 01-20-2007, 10:25 PM   #2
novacivic
Member#: 117980
2005 sti
wr blue
probably bent valves and yes it can be done in the car.
novacivic is offline   Reply With Quote
FS: EJ205 WRX driver's side lower cam gear and cam gear/timing belt cover gling Engine/Power/Exhaust 5 11-11-2010 07:25 AM
avcs cam gears, and exhaust cam gears. starace Engine/Power/Exhaust 3 06-11-2008 12:21 PM
Custom cam gears for USDM WRX heads running on a 7 tooth cam gear. Brydon Subaru Conversions 2 05-01-2007 08:19 PM
cam gear rotation jimtweet Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-29-2007 01:06 AM
Help cam gears?? newgensti Pre-2002 Factory Turbo Powertrain 7 07-13-2006 02:08 PM
