Old 02-13-2007, 01:58 PM   #1
thejean
Member#: 17763
Default How long does it take to manually prime the engine with oil?
Hey fellas. I flipped the motor over when it was on the engine stand and filled the pump with oil. The engine is now in the car and I filled it with oil, including the filter. Trying to manually prime the engine with ratchet from the crank pulley but it seems to be taking forever. How long does this usually take anyway? JC
thejean is offline   Reply With Quote
Old 02-13-2007, 02:12 PM   #2
Dizastical
Member#: 45444
2004 STI
I have built about 10 STI motors. Each time to prime the motors I disconnect the injectors and crank the motor with the key for 15 seconds about 8 times. I have yet to have any problems with this method. Good luck.
Dave
Dizastical is offline   Reply With Quote
Old 02-13-2007, 02:52 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
^^^ Agreed, this is a pretty standard way of priming, at least in Subarus.
8Complex is offline   Reply With Quote
Old 02-13-2007, 03:28 PM   #4
thejean
Member#: 17763
K, I'll do that then. Thanks fellas. I was cranking for like 10 minutes and then figured that the crank speed was not enough to prime. The oil pump looks centrifugal, not positive displacement so that would make sense.
Old 02-13-2007, 06:10 PM   #5
Starkiller
Member#: 82741
2007 350Z Silver
Disconnect the injectors or disable the fuel pump?
Starkiller is offline   Reply With Quote
Old 02-13-2007, 06:46 PM   #6
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
One way to confirm this is take the banjo bolt out of your turbo. Wait until you see oil and your real close.
JMK508 is offline   Reply With Quote
Old 02-13-2007, 06:46 PM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Either/or. You might get the motor to pop at first if your fuel system is still pressurized and you just disable the pump.
Really, the easiest way is if you have the stock ECU, just hold the accellerator to the floor and crank over the motor. The ECU automatically cuts the injectors when your throttle is open fully and you're trying to start the car -- THIS MAY NOT WORK ON DRIVE-BY-WIRE CARS, I don't know for sure.
Old 02-18-2007, 02:22 AM   #8
subie4me
Member#: 89218
take spark plugs OUT! Crank until pressure comes up. If stubborn, remove oil filter, squirt oil in small hole seen with filter removed. Crank til oil comes out , then put the filter back on.. Crank some more till pressure is up, put plugs back in. You don't want to be cranking a new engine over without oil presure, and the load on the rod bearings caused by compression.
subie4me is offline   Reply With Quote
Old 02-18-2007, 03:59 AM   #9
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Why would you need to take the plugs out? just unhook the engine harness on the left side and the car will not have spark.
RS_to_WRX_swap is offline   Reply With Quote
Old 02-18-2007, 05:37 PM   #10
spooln04
Member#: 85421
92 EG all mota
Listen, this is the proper way to prime a new engine or turbo.
Underneath the passenger side of the dashboard, next to the computer there are 3 plugs. You have to remove the pass side door sill to access them. Disconnect the big brown plug and the smaller green plug next to it. By doing this you are disabling the fuel and spark.
Now crank the engine over 5-10 times for about 5 seconds each.
You can also you this method for performing a compression test.
Don
spooln04 is offline   Reply With Quote
Old 02-18-2007, 06:01 PM   #11
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I think he's referring to pulling the plugs so there is no compression in the cylinders. No oil + compression probably puts some slight wear on the bearings, but I hardly think it enough to worry about unless the motor is going to be used to the edge of it's life.
Old 02-18-2007, 09:46 PM   #12
modaddict
Member#: 95840
sold to a good bud
awaiting next car
I have also thought about pulling my plugs when priming the engine. Let me ask a few questions>
1. Has everyone performed a compression test? Then you'll know that just for numbers sake, its around 150psi.
2. Has anyone performed a running compression test? Thats right, screw in the compression gauge and start the car. You will see it is about 1/3 or so of the psi....50-75psi.
Now, when the plugs are pulled and there is no compression, the rod bearings are not getting squished. while this may be anal, I think it cannot hurt anything. it's just a little labor intensive.
To me, priming the engine with all the plugs it could be slightly harder on the engine, and there probably isn't any proof of this. When i do my engine, I will probably either pull the plugs out and crank it, or just fill the filter and fire the bish up. The assebly lube should provide protection for that 2-3 seconds of starvation.
Hell, us ej257 guys probably get oil starvation at 7k+ rpms
modaddict is offline   Reply With Quote
Old 02-18-2007, 10:43 PM   #13
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
I just think its a waste of time to pull the plugs. Not like its a big deal, so do it if it makes you happy. Compression is not hard on bearings because its gradual and not much force at all. The power stroke is what you don't want an unprimed motor to see. Who knows if priming is even necessary. its not like there are people willing to test it on their motor.
After all, whats assembly lube for?
Old 02-18-2007, 10:47 PM   #14
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
I was just about to say, thats what assembly lube is for. If you use it properly, you should be covered for the first cranks to get oil in the galleys.
cdvma is offline   Reply With Quote
Old 02-19-2007, 01:03 AM   #15
Assassin4457
Member#: 96773
04 WRX, RIP GC8
Regardless it wouldn't hurt the pull the plugs. Definitely LESS strain than if they were in. Might not be alot to do any damage, but better safe than sorry. Take care of your car, and the car will take care of you.
Assassin4457 is offline   Reply With Quote
Old 02-19-2007, 03:43 AM   #16
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Great trick, I didn't know that! Should also help make sure the engine is fully primed after an oil change.
drees is offline   Reply With Quote
Old 02-19-2007, 04:40 AM   #17
modaddict
Member#: 95840
sold to a good bud
awaiting next car
it does not work with my DBW 04 sti.
Old 02-19-2007, 06:23 AM   #18
Brydon
Member#: 107569
1998 Forester S
SRP
As a added way to do this: Pull the 15amp fuse labed ign behind the coin try. This disables fuel, spark and the ecu. so you get no fuel pump. I have had at least one motor that had all new parts that did not want to prime. When the oil pumps are new they require a lot of cranking and higher rpms work better. For that pulling the plugs can help because you help the motor crank faster and stress the starter less also.
Brydon is offline   Reply With Quote
Old 02-24-2007, 05:57 PM   #19
Cosie Convert
Member#: 13627
96 Type RA
[email protected] Street Legal!
Take that 150 psi compression pressure and multiply it by the area of your piston and you may be surprised to find how many tons of force you have on your new, unpressurised bearings !
If you are not going to remove the plugs before cranking then you would be better just starting it straight away as the forces are less than half due to the plenum vacuum reducing the peak compression pressure (even considering combustion forces)
Cosie Convert is offline   Reply With Quote
Old 02-24-2007, 06:43 PM   #20
Got Boost?
Member#: 113096
06 sti
assembly lube = the winner
Got Boost? is offline   Reply With Quote
How long does it take to do a 30k service at the dealer BrigadoonB Service & Maintenance 8 01-31-2007 12:55 PM
How long does it take to blow out the center differential? Wrench40 Newbies & FAQs 34 12-16-2006 01:10 PM
Holy crap - how long does it take to tell us the freakin' weather?!? Hazdaz Off-Topic 6 11-13-2005 12:40 AM
How long does it take to make corn on the cob..... DriftRS Off-Topic 27 07-01-2004 04:55 PM
Greddy (so how long does it take to make a can with two holes?) turboICE Vendor Reviews 7 05-09-2003 12:32 AM
