Old 01-21-2007, 11:04 AM   #1
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Default 07 STi ECU ROM
Anyone have a ROM file for an 07 STi non-ltd? Just looking to use Enginuity to look around my stock ROM file and learn all the different parameters.
Thanks!
Acejam2k is offline   Reply With Quote
Old 01-21-2007, 11:57 AM   #2
Nuke209
Member#: 108089
2003 WRX
NF Performance
www.scoobypedia.co.uk
there's the 07 sti rom in there, look around
Nuke209 is offline   Reply With Quote
Old 01-23-2007, 08:58 AM   #3
sean18337
Member#: 135588
2007 STI *SOLD*
Has anybody successfully tuned a 07 STI with Enginuity?
If so what version of Enginuity and what cable..
sean18337 is offline   Reply With Quote
Old 01-23-2007, 09:04 AM   #4
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
http://www.scoobypedia.co.uk/index.p...patibilityList
2007 WRX/STi
A2UG000J
Best approach would be to download your ROM and compare it to this identified ROM...
xcntrk75 is offline   Reply With Quote
Old 01-23-2007, 10:19 AM   #5
Tea cups
Member#: 103136
The definitions in Enginuity are preliminary for the only 07 usdm sti rom that had been read with Ecuflash and uploaded which happened to be a limited. More disassembly needs to be done to verify for the 07 sti.
I don't know of anyone who has flashed an 07 sti with Ecuflash, though. There has been a guy flashing an 07 wrx, but these roms are very similar to the 06 wrx whereas the 07 sti is drastically different from the 06. If you want to try, you need the tactrix cable to do it.
Tea cups is offline   Reply With Quote
07 STI ECU Pinout BlackFlame Electrical & Lighting 1 09-28-2008 01:19 PM
Looking for 07 STI ECU Pinout silentt Electrical & Lighting 2 05-16-2008 12:43 AM
07 Sti ECU Diagram needed Jimmy168 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 05-14-2008 10:19 PM
07 sti ecu retrofit? aznatama Engine Management & Tuning 3 04-01-2007 08:51 PM
07 STI ECU swap able? jnorth85 Engine Management & Tuning 2 02-22-2007 05:38 PM
