Old 01-21-2007, 12:53 PM   #1
ECUboy
Member#: 138360
Default .......
ECUboy is offline   Reply With Quote
Old 01-21-2007, 01:15 PM   #2
testes1010
Member#: 47145
2012 Gas Saver
I assume your running solid 8's in the KC map?
the gutted stock DP is killing you....the flat design sucks donkey balls on IWG turbos....the stock midpipe, etc is hurting you as well.
testes1010 is offline   Reply With Quote
Old 01-21-2007, 01:45 PM   #3
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Originally Posted by ECUboy View Post
I had my 05 WRX recently installed a TD05-18G and tuned using open source. I was disappointed with it's performance, maybe I expect a 18G to do a lot better. Hope to get some expect advise here.
Who tuned it?
I have attached datalog below, this log was done on a 3rd gear pull on flat road. In the log file, my ECU pull timing at 5130rpm which I don't understand why.
Look at the amount of timing being run. What don't you get? 18* of timing that early on that setup is asking for it.
RPM MAF IAT Ignition KPH Knock Correction IDC Air Flow Sensor Voltage WGDC AFR Knock Signal IAM Engine Load Boost (Bar)
4123 147.58 55 17 60 8 32.54 3.82 89.8 11.92 0 16 4.31 1.12
4472 174.62 55 14 64 8 41.03 4.06 89.8 11.49 0 16 4.75 1.501
4845 176.3 54 18 69 8 41.34 4.1 67.06 11.52 0 16 4.5 1.491
5130 190.77 54 14 75 4 43.77 4.16 63.53 11.44 0 16 4.41 1.391
Assuming that's a wideband, you could probably be adding fuel to alleviate det/knock as well. Getting down towards 11.0 would help and could possibly be removed later once timing is saner.
lancelucas is offline   Reply With Quote
Old 01-21-2007, 02:00 PM   #4
ECUboy
Member#: 138360
Old 01-21-2007, 02:53 PM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Stock exhaust components FTL. I don't think Jesus himself could give you a good tune with that crappy exhaust on their. There some reason you have all the Sean P-diddy components mixed in with Ghetto Fabulous stuff? You needs an exhaust stat is your first problem. Not sure of normal uppipe sizing, but 2.5" uppipe sounds too big to me as well. Why the SARD FPR? Where do you live that you get 98 octane?
Old 01-21-2007, 06:15 PM   #6
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
the gutted stock exhaust is choking your turbo.
you have upgraded the intake side of your
motor and did not upgrade your exhaust...
RPM Ignition Knock Correction
4123 17 8 16 0
4472 14 8 16 0
4845 18 8 16 0..see this timing value? from the previous value at 4472 timing is 14.
5130 14 4 16 0
5411 16 5 16 0
i would lower this value to 14 just to see if the ecu
does not pull timing. a timing change more than a few..
key word..few..degrees will make the ecu do things like pull
timing when you pushing 1.4 bar..20 psi...
try to smooth out your timing..jumping around does not make power.
but now you know this..
Old 01-21-2007, 09:51 PM   #7
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Thanks for both testes1010 and lancelucas response.
Sorry for the messy log attached. re-attach for better view.
The timing pull at 5130rpm was something I don't understand. There's zero knock signal but KC reduces to 4.
The KC reduction at 5130 is prob. due to the 18* at the previous reading. Follow the advice given and drop it to 14* there
blkscooby is offline   Reply With Quote
Old 01-21-2007, 10:12 PM   #8
page02wrx
Member#: 124053
Back to BONE STOCK
1.6x i think is what the ID of a normal up pipe flange should measure when it connects turbo....
2.5'' is HUGE and is probably one of the main reasons he spools so slow....
page02wrx is offline   Reply With Quote
Old 01-22-2007, 11:17 AM   #9
w_o_t_boy
Member#: 126791
You're not necessarily going to see anything in the knock signal column. There's no reason to log it. A knock event is so brief the logger doesn't usually catch it, but your ECU is keeping track. What are you using for tuning?
w_o_t_boy is offline   Reply With Quote
Input needed - Your thoughts on my new car project. SubaruCO Off-Topic 2 07-21-2004 05:52 PM
Need your thoughts on my site scottm1978 Off-Topic 28 11-21-2003 11:41 PM
Need your opinions on my new rims... Hank3 Tire & Wheel 10 06-20-2003 04:44 PM
Please post your comments on my skidplates here Lachute Performance Car Part Reviews 18 08-03-2002 04:02 PM
Need your opinions on my site..... Rubasu Tri-State Area Forum 9 08-13-2001 01:18 PM
