Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 01-21-2007, 03:55 PM   #1
Member#: 127048
97 Impreza coupe
Default auto to manual wiring
Hi. I've been looking around for info on auto to manual conversions and I've read that the wiring can be a pain. I didn't evan think there was wiring to do besides removal. The auto trans. needs a computer to know when to shift based on throttle pos. and speed, while a stick is all mechanical and driver controlled. Apparently I'm wrong, so my question is; What wiring is needed? It's purpose? Does anyone know of any good threads that discuss this because I can't find any on the wiring portion of the swap.
That's the main pt. of this thread but tell me if my list is complete for parts I will need for the swap; transmission/drive-shaft/ rear-diff/ linkages/ slave & mast. cyl./ hydrolic lines/ clutch & brake pedal assemblys. I think that is everything but tell me if I've missing something. Thanks for the help.
LegacyWRX is offline   Reply With Quote
Old 01-21-2007, 06:26 PM   #2
Member#: 112766
obos is offline   Reply With Quote
Old 01-21-2007, 07:45 PM   #3
Member#: 100610
Don't forget clutch/pressure plate/flywheel, shifter, are trans. crossmembers and mounts the same? You'll need to do wiring for the reverse lights and probably some other stuff like the clutch switch.
ivwarrior is offline   Reply With Quote
2002: Auto to manual wiring diagrams located here. kilowhisky Subaru Conversions 7 09-08-2008 06:41 PM
Wire Help! auto to manual! JDM Importers Transmission (AT/MT) & Driveline 0 06-21-2006 12:17 PM
2.5 Auto to Manual tranny question sub human Normally Aspirated Powertrain 4 04-04-2001 01:25 PM
Converting a '99 auto to manual dandbest Technical Forum Archive 6 07-19-2000 12:18 AM
Is it possible to change from auto to manual? Andrew General Forum Archive 14 05-26-2000 11:18 AM
