Welcome to the North American Subaru Impreza Owners Club Tuesday September 1, 2015
Old 11-27-2001, 12:14 PM   #1
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Default Size of the factory option Oil temp drainplug?
I have the Subaru optional Guage pack that includes oil temperature. The temperature is measured through the pan drain plug. Do any of you guys know the actual size of this drain plug. It is a lot bigger than the standard one.
I am currently using a 1 1/16" wrench but I assume it's not quite right since it's not metric. Anybody know for sure?
skidplatez is offline   Reply With Quote
Old 11-29-2001, 12:37 AM   #2
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
I'm using a 1 1/16" too I don't have a metric open end big enough myself. It seems to work fine actually.
Peaty is offline   Reply With Quote
Old 11-29-2001, 12:51 AM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
1 1/16"= 1.0625"
A quick conversion nets that 27mm= 1.06299"
Since 27mm is only .00049 bigger, I'm guess that it is the right size
That wasn;t so hard
Eric
Eric SS is offline   Reply With Quote
Old 11-29-2001, 01:33 AM   #4
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
As it would have it, I replaced my standard plug with a Fumoto valve a few weeks ago. I just tried my standard plug and it fits a 17mm socket.
Measuring the diameter of the threads it looks like I get 2cm or 20mm.
That sounds about right, I think I was looking at a drain plug guide at PepBoys and it said somenewer subies had a 20x1.5 metric drain plug. I think there were a few older ones with 16x1.5, and the newestones weren't listed. But withthis quick measurement and that book, I'd bet that we have a 20x1.5 drain plug.
It sounds like your factory plug head is bigger by quite some margin. I'm guessing the threads are still the same, otherwise you'd need a whole new pan and not just a new plug.
iodine23 is offline   Reply With Quote
Old 11-29-2001, 07:11 AM   #5
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
You are correct, the head part is bigger to accomidate the thermocouple for the oil temp but the threads are the same.
Old 11-29-2001, 10:54 AM   #6
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Well that's so close I guess I'll stick with my 1 1/16" !
Old 11-29-2001, 11:15 AM   #7
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
Woops, I thought you were looking for the thread specs of the plug, not the head size.
Why not 225/45/17 tire size from the factory? txl146 Tire & Wheel 21 02-21-2006 07:01 PM
What size is the factory boost guage? Wraith Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-05-2004 02:36 AM
what size are the factory triple gauge pod gauges? M32WRXin3seconds Newbies & FAQs 1 07-24-2003 05:14 PM
what are the sizes of the speakers in the 01 Damon Car Audio, Video & Security 0 12-28-2001 06:19 PM
What Is The Size Of The Turbo On The 2002 WRX? Uthinkso Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-26-2001 08:15 AM
