Welcome to the North American Subaru Impreza Owners Club Thursday October 20, 2016
Old 01-21-2007, 07:37 PM   #1
Member#: 49620
2003 wrx wagon
Default Inspection Trouble
I'm having trouble getting my stock 2003 wrx wagon through inspection becuase the monitors of the computer havn't reset. In NJ they don't just check your exhaust, they hook into your computer to make sure that you havn't disabled a CEL.
In October at about 46000 miles I had the dealer replace the ABS chip as part of the free recall. After having work on the computer, it has to 'reboot' a process that it still has not completed, so the computer says that the evaporative systems and catalytic converter aren't ready. So I can't pass inspection! This is despite about 1500 miles of driving.
I spoke to the dealer and they said I had to drive it from cold at highway speeds for 10 miles or so, then turn it off, restart and drive another 10 miles at highway speed. I thought I did this, but it still hasn't reset.
Anybody have any ideas about what is going on? THis is a major pain in the....
expresswrx is offline   Reply With Quote
Old 01-21-2007, 07:42 PM   #2
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Actually the OBDII inspection is instead of a tailpipe test, not in addition. Many states including NY and PA are now doing this type of inspection for cars '96 and newer.
Anyway the replacement of your ABS unit should not have anything to do with your current issue. Even if they disconnected the battery at that time, which resets the ECU and the monitors, it should have all reset long ago through normal driving. The ABS unit itself has no connection to the ECU and does not affect the readiness monitors.
It would be helpful to have someone with a scanner check to see exactly which monitors are not resetting as this may indicate an underlying problem that needs to be addressed. Even if the CEL is not on there may be "pending codes" stored that can be read which can also be helpful
Anybody in PA have trouble getting inspection/emissions with a catless turboback? jay_barton Mid Atlantic Impreza Club -- MAIC 13 05-27-2009 05:39 PM
MD inspection troubles Jonny5isALIVE Mid Atlantic Impreza Club -- MAIC 20 03-24-2009 07:17 PM
Do you have trouble with passing inspection with your built motor? fastlanerex Built Motor Discussion 22 05-22-2008 12:58 PM
Inspection trouble deamon180 Service & Maintenance 6 12-08-2007 01:54 AM
OR/Federal inspection & mechanic for lot inspection polaris North West Impreza Club Forum -- NWIC 2 10-14-2004 08:37 PM
