Old 01-22-2007, 08:48 AM   #1
LUKEWMC
Member#: 119872
2004 STi
Default What psi should i run pilot sport a/s at?
What is the best pressure to run the pilot sports at on an 04 sti? Door placard and tire psi rating are different. If anybody remebers i have been having pulling problems which have lessened since all four tires were changed last week. still pulls, just not as bad. 1st through 3rd gear at full throttle no pull. 4th throuigh 6th and coasting at highway speeds it still drifts to the right. Want to know what psi i should try or i am going to request my money back and get Bridgestone Potenza RE960AS Pole Positions. Thanks!
LUKEWMC is offline   Reply With Quote
Old 01-22-2007, 10:33 AM   #2
krzyss
Member#: 8365
2013 Ford Focus SE
What tire psi rating are you refering to?
If the one that is on sidewall it is maximum cold pressure.
Use placard as staring point. Then go up (if you so desire) but not above max pressure.
Krzys
krzyss is offline   Reply With Quote
what psi are you running on stage 2 wrx the real suby dude AccessPort 14 05-21-2007 02:59 PM
At what psi are you green users maxing the map at 5v? kenlee Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 30 11-03-2005 10:37 PM
for partial throttle - what psi should read rbmour Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-28-2004 08:39 PM
What psi are you running in your RE92s? Enkidu Tire & Wheel 21 11-12-2003 05:59 AM
Minnam Turbo Owners - What psi are you running? Sean McElderry General Forum Archive 7 06-16-2000 05:01 AM
