Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 01-22-2007, 03:18 PM   #1
tacomaprime
Member#: 70572
2005 Tacoma
Default Widest tire on stock 05 WRX 16" rim
I am not buying new tires right now, but maybe next fall, depending on my money situation. My question is, what is the widest tire I can safely put on the stock 05 WRX 16" rim? It's the stock re92's right now, which are 205. Can I put a 215 on there?
tacomaprime is offline   Reply With Quote
Old 01-22-2007, 03:21 PM   #2
VpointVick
Member#: 93193
'03 325iT
Mysticblau
I'm running 215/45-16 Hankook Z-212's. Works great.
I had thought about 225/45, but heard from others that it flexing the sidewalls that much would kill my turn-in feel.
VpointVick is offline   Reply With Quote
Old 01-22-2007, 06:24 PM   #3
h62962
Member#: 103183
Boy that's an awful short tire (about 1 1/4" shorter than the OE size). Doesn't it look kind of funny?
h62962 is offline   Reply With Quote
Old 01-22-2007, 07:43 PM   #4
VpointVick
Member#: 93193
'03 325iT
Mysticblau
It's only about a half inch shorter in diameter, but, it does look a little funnier than I had hoped.
The gearing is much better for auto-x, though.
Old 01-22-2007, 11:02 PM   #5
pornie
Member#: 5620
i ran 225/50 kumho mx's. definitely killed turn in, but grip levels were definitely up over the re-92's
pornie is offline   Reply With Quote
Old 01-22-2007, 11:12 PM   #6
tacomaprime
Member#: 70572
2005 Tacoma
excuse my stupidity, but what is "turn in"?
Old 01-22-2007, 11:46 PM   #7
srfrdude21
Member#: 127924
2006 WRX TR SPT
Aspen WHite
turn in is the Intial "bite" into a corner. With those wider tires, the tire will start the turn noticeably before the rest of the car resulting in a somewhat mushy, understeerish feel in the initial few moments of the turn. I wouldn't be suprised if it makes the car a little funky in the slolam autocrossing.... Id love to hear Vpointvicks stance on that last statement before I write it down as fact....and try it on my car.
srfrdude21 is offline   Reply With Quote
Old 01-22-2007, 11:47 PM   #8
srfrdude21
Member#: 127924
2006 WRX TR SPT
Aspen WHite
...all that assuming u keep the same size rim, before people start screaming at me for being a n00b*****
Old 01-22-2007, 11:52 PM   #9
VpointVick
Member#: 93193
'03 325iT
Mysticblau
You've got it right.
All that flexy sidewall makes it take a while before the car actually starts to move in the direction that the wheels are pointed.
Kind of like the difference between rubber and urethane suspension bushings; less deflection= better response.
Old 01-23-2007, 12:29 AM   #10
REX8
Member#: 24038
All depends on the tire though...
A 225 50 16 RT615 will not feel nearly as bad as a 225 50 16 all-season, or not so stiff summer tire.
215 50's are a nice compromise...but again, its all about what tire you are putting on there, and what you plan to do with it.
Old 01-23-2007, 12:44 AM   #11
pornie
Member#: 5620
the fun part was the back end with the stock setup on it, it did start to swing around w/ trailing throttle at "quicker" speeds.
205/50/17 winter tires on stock 05 STi 17x8 rims titsataki Tire & Wheel 8 11-05-2006 07:49 AM
Widest tire on stock 16" wheel modest1 Tire & Wheel 4 01-22-2006 11:00 PM
how big of a tire on stock 05 wrx rims? surfer5567 Tire & Wheel 7 09-29-2004 08:54 PM
Widest tire on stock 16" rims??? asbWRX04 Tire & Wheel 9 04-28-2004 08:08 PM
Widest tires on stock 2001 RS 16" Wheel?? ITR&RSGUY Brakes, Steering & Suspension 3 07-25-2001 04:49 PM
