Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 01-22-2007, 02:42 PM   #1
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
Default My bad water pump led to a bad radiator
I have the Murphys law running rampant on me.
So my water pump went out. I grabbed a good one sitting around, i threw it on my car with a gasket and some high heat silicone.
I got that taken care of, purged the system of air, and took off on a test drive. The heat begins to go up and eventually pegs.
I get on the phone with a +20 year subaru mechanic and after describing:
* running temp at idle and O/H during driving
* HG job less than 30,000 miles
* replaced water pump
* Brand new thermostat
* Heat from the heater core UNTIL driving
He says, it sounds like my radiator. When you drive the radiator depends more on the air passing through it then the fans. It begins to O/H and expel extra coolant from the radiator that's why the air coming from your heater core goes cold.
So, with all of the problems that i've been having lately with my car. I'm skeptical that that's the problem but at the same time I can't really rule out the idea.
I JUST WANT MY CAR TO RUN WITHOUT ISSUES!
~Mike
pilfflip is offline   Reply With Quote
Old 01-22-2007, 02:48 PM   #2
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Sorry to hear of this problem. If you find you’re looking for a new radiator, I have a used one out of a 98’ LGT, yours for $40 bucks + shipping.
xcntrk75 is offline   Reply With Quote
Old 01-22-2007, 06:30 PM   #3
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Are you sure it's completely purged of air? Sounds like mine when I still had a small air bubble.
Plays_With_toys is offline   Reply With Quote
Old 01-23-2007, 01:48 AM   #4
geraDOT
Member#: 138451
1991 Legacy, 2.2L
cherry red
Did he checked-out radiator cap? Check it or replace with new one just for try...
IMHO I would recommend also 1) to carry out pressure test of cooling system, 2) to check the readiator neck for rust or debris
3) if the hose from radiator to reservoir tank is loose then it pulls the air in instead of coolant from tank.
geraDOT is offline   Reply With Quote
Old 01-23-2007, 09:40 AM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Radiator cap? Old hose that's collapsing once you're driving?
The mechanic's explanation doesn't make much sense to me.
Pat
Old 01-23-2007, 03:15 PM   #6
MYfirst00
Member#: 22928
2011 Outback 3.6R
Gray
The mechanic's explanation makes sense to me. He's describing if there's not a lot of fluid going through the radiator core because of it overheating into the resevoir or whatnot, then the fluid's not going to make it over to the heater core.
With my first RS, I had to have the radiator replaced at the same time as the waterpump. Luckily it was under warranty.
MYfirst00 is offline   Reply With Quote
Old 01-23-2007, 05:51 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I understand that - that's standard Subaru blown head gasket behavior, and I've been through that 3 times with my car.
I don't understand what the car being in motion and the radiator "depending more on air flow through it than the fans" has to do with anything, though. His description just doesn't make any sense.
Pat
Old 01-23-2007, 05:59 PM   #8
MYfirst00
Member#: 22928
2011 Outback 3.6R
Gray
Ah, 10-4
Old 01-23-2007, 07:59 PM   #9
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Subaru Coolant Conditioner ruined at least two radiators on my car, three sets of head gaskets and two head resurfacings.
Thankfully my last overheating problem seemed to be as simple as the thermostat. I figured it was another clogged radiator, but started with the cheapest fix first.
DLC is offline   Reply With Quote
Old 01-23-2007, 08:27 PM   #10
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
I thought it made sense when he explained it to me. Nevertheless i'm going to replace the radiator.
But to shoot down the possibilities that were thrown out. The reservoir hose is good, I already checked that.
The hose to the heater core, top and bottom, and aux water pump hose are all replaced during this minor fiasco, and the cap is still in hop opr condition.
~Mike
Old 01-23-2007, 10:46 PM   #11
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
The hose to the heater core, top and bottom, and aux water pump hose are all replaced during this minor fiasco...
I'm less concerned about those hoses and more concerned about the radiator hoses, the ones that carry the bulk of the coolant flow to/from the radiator. Have they been replaced?
Originally Posted by pifflip
...and the cap is still in hop opr condition.
"hop opr"?
Pat
Old 01-24-2007, 03:11 PM   #12
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Originally Posted by Patrick Olsen View Post
"hop opr"?
Pat
"hop opr" = Top Operational condition
A radiator either fails because of corrosion causing a leakage, or crud gets into the the cores causing either a full or partial blockage and coolant doesn't flow as nicely as it should.
Jonathan is offline   Reply With Quote
Old 01-25-2007, 10:34 PM   #13
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
Sorry, the "hop opr" was meant to say "good opr(short for operating)". I was on my blackberry when I left that posting and must've missed a button.
The top and bottom radiator hose are good, the bottom one has been replaced recently and i have no leaking problems from the top one.
Could the clogging of a radiator be caused by the blowing of a head gasket? My brother had his HGs blow and he said he had to flush the radiator because of all the junk that was in it after they blew. And since i've recently had my HGs. It doesn't seem that far fetched...
~Mike
is my power steering pump supposed to be this loud? XanRules Service & Maintenance 9 04-18-2010 01:45 AM
What does a bad water pump sound like? BacDoc Off-Topic 51 12-23-2008 07:00 PM
When do the timing belt/water pump need to be replaced? Bilybobjef Service & Maintenance 10 07-08-2007 09:52 PM
WTB: WRX Water pump, Thermostat housing and lower radiator hose? CUNNINGHAM Private 'Wanted' Classifieds 1 04-13-2007 10:52 AM
Should I replace my wrx's water pump? trite Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-08-2005 09:46 PM
