Old 01-22-2007, 03:06 PM   #1
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Default Rear diff & axles FAQ
jared's school on rear diffs, axles and splines:
there are at least 6 setups
on the diff side:
22 splines - early diffs and non LDS diffs .. identifiable by single large flower looking nut on side of diff assembly pict
25/20 splines - early jdm LSDs -identifiable by plate and 5 bolts on side of diff - 3 sets of teeth are visible if you look through the diff axle is dual spline axle has tapered end and spirals befor the splines pict,pict
25/19 splines - early jdm LSDs -identifiable by plate and 5 bolts on side of diff - 3 sets of teeth are visible if you look through the diff most likely from a earle JDM legacy 89-99 pict
25 splines - later diffs and LSDs -identifiable by plate and 5 bolts on side of diff
outtie - has a male spline setup on diff (89-93? legacy turbo only) look like front axels pict
R180 - ????
on the hub side:
r160 hubs have 24 splines
r180 hubs have 27 splines
here is where it gets tough
axle lengths changed some where around 2000
in an older GC for example the the drive line is centered in the car. due to one side of the diff being bigger the passenger side axle is longer (driver shorter)
in the new cars say a gda or 2000+ legacy the diff is off-center and the axles are the same length
the difficult thing is to find a set of unequal length 25 spline axles i found a set on a 98 forester w/ lsd
the open 25 spline spider gears are much bigger than the 22 spline opens ..
picts of a r180 and L diffs would be helpfull pm me if you need hosting
Old 01-22-2007, 03:15 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
It's axles...
Old 01-22-2007, 03:15 PM   #3
shemoves
Member#: 80663
2005 STi
Very cool. Looks like we are getting some good drivetrain info compiled.
Hmm...regarding center/off-center drivelines and axle lengths...do you think I would have a problem swapping an '04+ WRX drivetrain into a '92 Legacy SS?
shemoves is offline   Reply With Quote
Old 01-22-2007, 03:19 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hard to say ...i am not sure if the mount changed or the diff itself
and yes the diff i bought from j-hot is the 3 spline setup so when i am done i will have a set of every r160 axel ever
Old 02-09-2007, 05:48 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
so i added some things thought i would bump it
Old 02-18-2007, 09:17 PM   #6
nick d
Member#: 102126
i have a cold air intake in my 2.5 rs 2005, the car is using oil, what can be the problem?
nick d is offline   Reply With Quote
Old 02-18-2007, 10:01 PM   #7
Daishi00
Member#: 78952
2005 WRX
CGM
I'm sure you already know but since you have a section on axle length you might want to add in that the 05+ STi's also have longer axles by 0.5".
Daishi00 is offline   Reply With Quote
Old 02-18-2007, 11:07 PM   #8
DSM_Outback
Member#: 56345
93 Swapped L
Green
It sounds like a bad knueder valve: after a while oxygen (from the CAI) builds up on the malarganite seating surfaces causing windage flutter which could be the cause of your oil consumption.
Edit: This is a bad joke.
DSM_Outback is offline   Reply With Quote
Old 02-19-2007, 07:14 PM   #9
nick d
Member#: 102126
how would i fix this problem?
Old 02-19-2007, 08:29 PM   #10
kheff46
Member#: 66739
2002 WRX wagon
Thumbs down
post it in the right forum?!? maybe?!?
may help a little. and say your sorry for hijacking. i wish this form of jacking was illegal too.
--keith
kheff46 is offline   Reply With Quote
Old 02-20-2007, 11:38 AM   #11
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
grrr how the hell did you get cold air intake from axle and diff faq grrr take it else where
Old 02-13-2008, 04:51 PM   #12
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
one year bump...
when did they switch over to 25 spline for the open diffs? I'm going to guess 96 with the tranny as well.
Old 02-13-2008, 06:25 PM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
sounds plausible but could be much later .. iirc the 99 rs is a 22 spline
Old 02-13-2008, 06:32 PM   #14
kheff46
Member#: 66739
2002 WRX wagon
my 95L and 96 had same axles. my 98 OBS(and V4 STi) had the same spline count as newer WRX/RS/foresters and was different than my 95-96L. some later 96 build dates(my97) may have had this running change like the phase I/II era of engine build dates.
just what i've encountered so far!
--keith
Old 03-14-2008, 12:17 AM   #15
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
don't-pull-me-over Silver
subscribed.
I'm too tired to read this and count splines right now, but I'm trying to figure out what shafts I need for my newly purchased mechanical 4.11 rear LSD from V2 or V3 JDM WRX (seller did not know which version).
I've been looking for a good thread on this for several days now. I'm so happy I finally found this.
Danny Boy is offline   Reply With Quote
Old 04-08-2015, 11:39 AM   #16
Lifeisgood
Member#: 162117
2000 2.5 RS Sedan
Silverthorn Metallic
So I realize that I am bumping a very old thread, but I ended up with an early 4.11 LSD diff and am having trouble finding axles for it...
"25/20 splines - early jdm LSDs -identifiable by plate and 5 bolts on side of diff - 3 sets of teeth are visible if you look through the diff axle is dual spline axle has tapered end and spirals befor the splines"
Does anyone have any suggestions as to where to look for a set?
Lifeisgood is offline   Reply With Quote
Old 04-10-2015, 06:26 PM   #17
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Hi L,
The Rallispec chart lists models. Perhaps Ebay UK or even down under have them listed. Unless you read Japanese and can use one of the Japan Auction sites?
Td
wtdash is offline   Reply With Quote
Old 04-22-2015, 06:16 PM   #18
Lifeisgood
Member#: 162117
2000 2.5 RS Sedan
Thanks for the reply. I've already looked at the rallispec chart, however there are so many different JDM R160 VLSD diffs that I have no idea really where to start. I'll keep digging though...
04 Rs rear diff and axeles for sale happy69 Drivetrain 0 03-12-2007 11:44 PM
I need a driveshaft and rear diff w/ axels!! wrxtrev Private 'Wanted' Classifieds 16 11-07-2006 12:14 PM
uppipe, worx bov, R180 rear diff, sti axels gotti Private 'For Sale' Classifieds 7 08-08-2005 12:29 PM
02 wrx rear diff & axels turbopro Private 'For Sale' Classifieds 1 09-16-2004 06:53 AM
2002 rear diff and axels f.s turbopro Private 'For Sale' Classifieds 3 09-16-2004 06:45 AM
