Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 01-22-2007, 07:40 PM   #1
adizon
Member#: 55718
02 WRX sedan
Default Reverse staggered wheels.
So I was looking through the Japanese magazine Hyper Rev. and noticed that some of the featured race cars would run say Front: 17x8.5 Rear: 17x8, or Front: 18x8.5 Rear: 18x8 etc. , but the tire sizes would be the same like say a 245 or 255!
Now do they no know something that we don't? Does it help turn in better? Does just having a wider wheel (without changing the tire size) make enough of a difference that a lot of those cars would have that?
adizon is offline   Reply With Quote
Old 01-22-2007, 07:49 PM   #2
eBay WRX
Member#: 138493
04 Impreza WRX
User 'drivrswntd' did a reverse staggered setup.
Originally Posted by drivrswntd View Post
Finally got my pictures from NHIS when i was up there about a month ago. 04 sti, havent really done any performance mods, all of the r&d has gone into suspension and braking. Susp and braking setup is as follows
Zeal Function v6 12k/10k
Cusco frt and rear sways, (rear sway on middle setting)
Cusco ti strut bar
Autopower 4pt roll bar
Sti lateral links
Sti trailing arms
Enkei tarmacs 17x9 frt and 17x8.5 rear
Advan neova's 255/40/17
-3.5 camber frt, -2 rear
Racecomp 2 piece frt rotors
Pagid blue pads all around
Goodridge lines, ate super blue fluid
Cooked my rear rotors at this event. Stock rear rotors, are warped beyond belief. I came off the track and they were a nice solid blue color. Working on gettin some 2 piece rear rotors as replacements.
eBay WRX is offline   Reply With Quote
Old 01-22-2007, 08:09 PM   #3
bdi
Member#: 66033
05 STi
This is old news and a well known trick so no they dont know something that we dont.
If set up correct, it will help with turn-in. The wider wheel will help reduce tire sidewall flex and give you a slightly larger tire contact patch thus giving you more front end grip and better steering response.
Just remember that us AWD guys have to use the same size tire on all 4 corners!
bdi is offline   Reply With Quote
Old 01-22-2007, 08:34 PM   #4
adizon
Member#: 55718
02 WRX sedan
Sweet, makes sense! I just didn't see too much of the NASIOC community doin this.
Thanks man!
Old 01-22-2007, 10:46 PM   #5
WRblueX_Guy
Member#: 53247
Thanks man!
Not many people do it on street cars. If you notice, some track/race cars on here run a wider wheel in the front, as well as different offsets front and rear.
WRblueX_Guy is offline   Reply With Quote
Old 01-23-2007, 07:34 PM   #6
bdi
Member#: 66033
05 STi
Yes!! Was about to add this to my post but you beat me to it.
Old 01-23-2007, 09:01 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
If set up correct, it will help with turn-in. The wider wheel will help reduce tire sidewall flex and give you a slightly WIDER tire contact patch thus giving you more front end grip and better steering response.
....NOT larger
Old 01-24-2007, 04:57 AM   #8
Fogrider
Member#: 45806
'04 STI WRB
'95 GC8 Rally car, white
Originally Posted by Uncle Scotty View Post
....NOT larger
So does the contact patch retain its surface area or get smaller when rim width increases?
Fogrider is offline   Reply With Quote
Old 01-24-2007, 09:40 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
...just changes shape.
...and this gets discussed, here, regularly....read a bit and educate yourself
Staggered wheels on a WRX wyn525i Off-Topic 33 06-30-2006 04:06 PM
Staggered Wheel Size endeavor Tire & Wheel 5 08-26-2005 01:53 AM
Staggered Wheels/Tires really BAD idea zacek Tire & Wheel 25 03-20-2005 01:08 AM
reverse staggered tires? aspera Tire & Wheel 10 06-17-2004 10:05 PM
staggered wheels on a sti? D Spec Dc2 Tire & Wheel 9 01-25-2004 04:05 AM
