Welcome to the North American Subaru Impreza Owners Club Friday May 29, 2015
Old 01-22-2007, 08:20 PM   #1
mtm584
Member#: 90765
Default 105k service
What all does everyone recommend on this service. Timing belt, water pump?
mtm584 is offline   Reply With Quote
Old 01-22-2007, 08:56 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Never mind what "everyone" says, look in your service schedule that is in your owners manual package and also on the Subaru website, and follow that.
Old 01-23-2007, 12:51 PM   #3
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
IIRC the service schedule says to replace the timing belt. For my 105k I replaced the timing belt, tensioner, checked the pulleys for wear, replaced the crank and 2 cam seals (sohc), replaced the water pump, replaced the thermostat, replaced the upper and lower radiator hoses, and used new coolant.
The thermostat and water pump will need new gaskets as well.
Chav is offline   Reply With Quote
Old 01-23-2007, 09:23 PM   #4
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
We do an oil change, rotate and balance tires, Timing belt and drive belts(if needed) adjust valves(if app) and a fuel system service and the usual top fluids and set tire pressure.
blackfang is online now   Reply With Quote
Old 01-23-2007, 11:09 PM   #5
z&cobb
Member#: 12344
2002 2JC
blue
What's recommended in PM-3 Service Manual Section 1 is just the engine oil, engine oil filter, drive belts and camshaft belts.
I did a lot more than that since the engine was out, and the clutch was also serviced. I did the one fell swoop approach, and the Subie master mechanic put in 15 hours over a weekend. Each to his own I guess. Now I'm ready for the next upgrade level.
My stg 3 wrx does not see "easy" riding, and is closer to the severe service schedule on all the parts.
z&cobb is offline   Reply With Quote
Old 01-29-2007, 12:41 PM   #6
shemoves
Member#: 80663
2005 STi
Why don't you give me back the money you stole from me?
shemoves is offline   Reply With Quote
Old 03-25-2007, 06:10 PM   #7
chuckywang
Member#: 103654
2013 Sport Limited
Satin White
How much did the 105k service cost you?
chuckywang is offline   Reply With Quote
Old 03-29-2007, 07:07 AM   #8
gixxerg1
Member#: 34957
2003 wrx
mbp
yeh how much?
gixxerg1 is offline   Reply With Quote
Old 07-12-2007, 11:50 AM   #9
chuckywang
Member#: 103654
2013 Sport Limited
Satin White
bump for answer
Doing my 105k service soon, list of parts im getting Jay04WRX Service & Maintenance 14 01-07-2010 04:43 PM
105k Service Question Jncominco2 Rocky Mountains Impreza Club Forum -- RMIC 36 04-16-2009 07:32 PM
105k Service Questions Jncominco2 Newbies & FAQs 1 04-14-2009 09:46 PM
02 WRX. 105K service. What should I do and how much should I pay? st000 Bay Area Impreza Club Forum -- BAIC 6 10-12-2008 04:34 AM
'01 Forrester 105k service help/writeup?? kendogg41 Service & Maintenance 8 05-11-2008 10:18 AM
