Old 01-22-2007, 11:58 PM   #1
Blakjack
Member#: 138129
Default Knock sensor - known suspect?
Newbie (to this forum) just bought a '97 Outback Legacy 2.5 for cheap, can't get through emissions with knock sensor code permanent in memory.
I was going to replace it, wiring seems ok, but I figured it was worth a shot seeing if this is a part that is known to fail (also an expensive part). Don't have a hell of alot of experience working on this motor. Hope to change that soon.
Side info : Car has sat for some time, gas may have gone a little bad but runs fine and definitely doesn't knock.
Oil's a little thin, but not more than one would expect.
Thanks for the input!
Blakjack is offline   Reply With Quote
Old 01-23-2007, 11:44 AM   #2
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
Subaru had a problem with knock sensors in that year, make sure that the sensor is grounded (remove the mounting bolt and look for corrosion) if thats ok replace the sensor.
crampfan is offline   Reply With Quote
Old 01-23-2007, 11:44 AM   #3
Blakjack
Member#: 138129
Thanks, it looks good, I took it off and reinstalled it, same code. The fact my local parts store has it in stock is probably a good indication.
Thanks for your time.
Old 01-25-2007, 06:46 PM   #4
JRSC13
Member#: 49479
05 05xt sti stg 2
pp
really common
JRSC13 is offline   Reply With Quote
Old 01-26-2007, 09:03 PM   #5
Blakjack
Member#: 138129
Sweet, I'm used to nightmarish wiring issues with POS cars - sure would be nice if I could just install this new sensor and roll.
Thanks for all the help guys, letting me know this is a common problem is really the difference between me getting this car or not - VA emissions is kind of chitty.
Old 01-28-2007, 10:40 AM   #6
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
You will probably have to clear the codes after installing it, but you should be good after that. The torque spec is very low on that bolt- don't crush the sensor when you put the new one in.
Brian
Old 01-28-2007, 11:36 AM   #7
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Once it is installed clear the memory. The Sensor is around 95 bucks or so from the dealer.
blackfang is online now   Reply With Quote
Old 01-29-2007, 12:20 PM   #8
Blakjack
Member#: 138129
Thanks all, going to hammer at it today, anybody know where the damn thing is?
Old 01-30-2007, 03:37 PM   #9
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
/\/\ um....if you took it off and reinstalled it, I don't think it moved
sigh...it's on the left side, top, between the cyls. (left side is drivers side)
Old 01-30-2007, 04:22 PM   #10
Blakjack
Member#: 138129
Thanks. What I meant to say is that my emissions guy removed and reinstalled it.
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor, ex mani jakesurfin Engine/Power/Exhaust 9 06-15-2009 01:28 PM
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor jakesurfin TXIC Private Classifieds 4 06-15-2009 01:28 PM
2nd Knock Sensor Location, 2nd Knock Sensor Locatoin! SentinelSison UTEC 3 05-24-2006 10:06 PM
Jorge's Daily hash: Knock sensor, false knock, filters and electronics... RiftsWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 09-10-2003 10:49 AM
knock link or msd knock sensor? wrxtcy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-22-2002 07:21 PM
