Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 01-23-2007, 01:07 PM   #1
bthomas
Member#: 50004
02 wrb
Default 02 with 115K miles
So my car has alot of miles on it but its still running strong. I've been trying to do less mods and more maintenance to keep it top notch.
Recently I've replaced:
Timing belt and accessory belts
O ring
water pump
Thermostat
tranny and diff fluid
spark plugs
brake pads
clutch
transmission (free from Subaru, long story...)
I've come across a good deal on a used td04 with about 25K. Should I pick it up and install it as preventive or just wait and she how much I can get out of the old stocker? Would it be worth my while? I want to keep the turbo stock for reliability and financially.
Is there anything else you could recommend that I keep an eye on?
I'll be doing a compression test come spring.
thanks for the suggestions.
bthomas is offline   Reply With Quote
Old 01-23-2007, 02:28 PM   #2
hoodscoob
Member#: 85140
2005 Legacy GT wagon
topazzzzz
If there is no play in the turbo shaft than don't worry about it. Check the coil packs, clean the MAF, check for leaks around your (stock) radiator where it is stamped, run compression test, take an oil sample to Blackstone Labs, CV boots, wheel bearings, DIY vaccuum leak test, clean up battery and grounding points, clean throttle body, run some seafoam through BOV vac hose. That's some things I can think of at the moment.
hoodscoob is offline   Reply With Quote
Old 01-23-2007, 08:15 PM   #3
illmatic
Member#: 3536
2013 SWP BRZ Limited
2002/2003 AW/PSM WRX
What other mods do you have? I've seen stock td04s go for $75 shipped. Send it to dead bolt and have it P&P.
illmatic is offline   Reply With Quote
Old 01-24-2007, 10:10 AM   #4
bthomas
Member#: 50004
02 wrb
I'm at stage 2. If I go the P & P route, can I keep the fuel pump and injectors stock? Does p&p increase the life of my turbo? I'm debating picking up a td04 for $100...
FS : (RI) 2004 STi with 16k miles $18500 Aiden12307 Private Vehicle 'For Sale' Classifieds 19 06-14-2010 05:40 AM
02 WRX 115k without timing belt Q? KitchenerWRX Service & Maintenance 3 11-27-2009 10:39 AM
Value of 93 Sentra SE-R 5sp with 115k miles? txl146 Off-Topic 29 05-22-2006 01:12 AM
02 with 34K miles w/slight door damage subbie02carrera Private Vehicle 'For Sale' Classifieds 15 07-15-2005 02:33 PM
02 WRX Engine and gearbox EJ205 with 20k miles. AZScoobie Private 'For Sale' Classifieds 20 07-24-2003 01:22 PM
