Old 01-23-2007, 03:43 PM   #1
delongedoug
Member#: 124113
and beyond!
Default Mixing tires up
I just bought an Evo("wrong forum", "boo", etc) that came with 2 snows in the rear and 2 summers in the front. Why? I don't know, that's irrelevant. So my question is: is it ok to put 2 new snows up front and then get 2 new summers with the current summers when that comes along? I know it's "better" to do all 4 at once, but is it a BIG deal?
Currently it has Continential Winter Contacts for winters and Sumitomos for summers if anyone was wondering. Which exact model, I'd have to check.
Thanks for helping out an AWD tire newb/traitor
delongedoug is offline   Reply With Quote
Old 01-23-2007, 03:47 PM   #2
Tire Rack Moderator
Member#: 1215
ext. 4362
it really depends on tread depth of the remaining tires .... and the reason you have a mixed set is because whomever owned the car before you could not afford it and was trying to cut every corner possible jsut to keep the car .... it was proabnably on the verge of being repo'd
over maintenance the car for the next few months as that is the first thing neglected when somebody is broke
Old 01-23-2007, 03:58 PM   #3
delongedoug
Member#: 124113
and beyond!
Yea, I'm definitely planning on running dedicated winter and summer wheel sets, and was caught off guard when I checked to see what tires were on there last night.
So as long as the tires aren't hella worn, it would be ok to run with 2 new ones and 2 used ones, winter and summer(not together obviously)? Then just replace all 4 of each set later on.
Old 01-23-2007, 10:20 PM   #4
krzyss
Member#: 8365
2013 Ford Focus SE
I suspect that Mitsubishi has similar requirements for tires like Subaru. Diameter must be within certain limit. Check manual and if it is the case take tape measure and check them.
If needed buy 4 new w tires.
This is what I think.
Krzys
krzyss is online now   Reply With Quote
Old 01-24-2007, 05:04 AM   #5
Fogrider
Member#: 45806
'04 STI WRB
'95 GC8 Rally car, white
If the tread height, mounted/inflated tire diameter old vs. new is within vehicle manufacturer's spec, you should be OK when you get your new pairs of tires. I would recommend you consider mounting "news" and "olds" as diagonal pairs so there is less difference in rolling diameter front vs rear axle.
Fogrider is offline   Reply With Quote
OT grillers, mix me up a marinade for me steak. volume311 Off-Topic 119 03-28-2006 02:50 PM
Are you a creature of habit or do you mix it up? Hamsterstyle Off-Topic 14 10-03-2005 06:37 PM
Tire Recommendation: Summer/AutoX/Track mix tire? DeusExMachina Tire & Wheel 9 07-05-2005 11:19 AM
Mixed things up a bit ... HappyEeyore Member's Car Gallery 10 08-30-2004 11:16 PM
Audi RS6 mixes it up with Vettes, Porches, BMWs etc... SpinAll4 Motorsports 1 04-03-2003 11:51 PM
