Old 01-23-2007, 03:27 PM   #1
kid22
Member#: 396
2000 2.5 RS-T
22WannaB
Default water pump replacement write up?
does anyone have or know where i can get a water pump replacement intructions? i tried scoobymods and found not luck. thanks.
kid22 is offline   Reply With Quote
Old 01-23-2007, 03:50 PM   #2
bthomas
Member#: 50004
02 wrb
Look up instructions to change the timing belt. Those will work because you have to get behind the timing belt covers. Then its basically plug and play. Dont forget to drain the coolant …or if you’re able to plug the lines somehow.
bthomas is offline   Reply With Quote
Old 01-23-2007, 05:05 PM   #3
kid22
Member#: 396
2000 2.5 RS-T
22WannaB
cool thanks, gives me a good starting point!
Water pump replacement at second timing belt replacement? doobie Service & Maintenance 1 10-19-2007 12:12 PM
Water Pump replacement write-up? WRX.357 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-12-2007 09:58 PM
Intimidated by water pump replacement procedure C-daleRidr Service & Maintenance 3 01-09-2004 11:23 AM
water pump replacement on 97 impreza awd4ever Service & Maintenance 4 07-31-2003 05:34 PM
water pump replacement? mpreza Service & Maintenance 2 03-19-2003 10:29 AM
