Old 01-23-2007, 05:48 PM   #1
gabrielh
Member#: 113641
2002 S2000
Default tires size with stock 16" rims?
What tires size can I put on my 16" stock rimes....it come with 205/55 (or50?) /16 stock.
Can I put larger tires on these rims without affecting the speedometer too much ?
Sorry for this noob question
gabrielh is offline   Reply With Quote
Old 01-23-2007, 06:24 PM   #2
epson1
Member#: 122909
2003 Evo 8
Apex Silver
you could go 215/195(i think) and 45/65(i think) don't quote me on that
epson1 is offline   Reply With Quote
Old 01-23-2007, 06:30 PM   #3
MT_WRX
Member#: 24409
'03 Comatose WRX
Wagon. Parked.
MT_WRX is offline   Reply With Quote
Old 01-23-2007, 06:32 PM   #4
REX8
Member#: 24038
225 50 is all you'd want to throw in 6.5" wheels for the street. No speedo change.
Old 01-23-2007, 06:32 PM   #5
hotrod
Member#: 14141
2002 Impreza WRX
Oversize tires (diameter) will always effect the speedometer. The only question is how much error your willing to put up with.
Go to "tirerack . com" and look at the revs/mile specs for the tires. Your speedometer error will be in direct proportion with the difference in revs/mile between the stock tire and the new tire.
For example if one tire has a revs/mile of 830 (which if I recall correctly is the stock potenza RE-92), and the other has a revs/mile of 854 then your speedometer will be in error by 854/830 = 1.0289 or a 2.89% error.
That means at a true ground speed of 60 mph, the new tire would read 2.89% low or 58.3 mph on the speedometer. As a result you would be running a bit faster than the speedometer said you were if you were showing 65 mph on the speedometer, with the new tire you would actually be going 2.89% faster or 66.87 mph.
In my experience its not much of an issue until speedometer error gets up around 10% then you will be running 5-10 mph faster than the speedometer says at highway speed. If your not careful that can get you a ticket if you push the speed limit anyway.
Larry
hotrod is offline   Reply With Quote
Old 01-23-2007, 06:35 PM   #6
flukewrx
Member#: 75081
2003 WRX
There are people running both 215/45/16 tires and 225/50/16 tires on the stock WRX wheels. Check out the Tire Size Calculator above to see how much of a difference it will be, but 225/50/16 is almost dead on to the 205/55/16 tire size in terms of Revs/Min (actually it looks like it is saying it IS Dead On, but different tires will vary that amount ( + ) or ( - ).
flukewrx is offline   Reply With Quote
Old 01-23-2007, 06:48 PM   #7
KmanRuffian
Member#: 48360
2011 WRX 5-door
225/50/16 is the size you want to go with for a slightly wider tire... I would only do a "plus zero" size like that with a stiff side-walled tire though. Next time post in the right forum and search said forum prior to posting. Thanks. Oh and that size will not affect the speedo at all, it is simply a slightly wider tire...the external diameter is the same as stock size. If you are looking for a lower profile tire on your stock rims then you're gonna screw with your speedo reading.
-D
KmanRuffian is offline   Reply With Quote
Old 01-23-2007, 11:40 PM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
or you could go with 205/50/16 and have he equivalent of a 4.11 transmission
Old 01-24-2007, 12:26 AM   #9
saharakid03
Member#: 70490
2005 WRX
225/50/16 is wat im using and theres a difference. from the stock size.
saharakid03 is offline   Reply With Quote
Old 01-24-2007, 02:36 AM   #10
KmanRuffian
Member#: 48360
2011 WRX 5-door
Yes 225/50/16 is wider than the stock tires... Any difference in circumference can be measured in mm and is negligible. Thus the reason it is referred to as a "plus zero" size. That size will not affect your speedo reading, period.
-D
Old 01-24-2007, 06:37 AM   #11
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Score!
Spenk is offline   Reply With Quote
Is there a sticky? What size tires can I run on Stock 16" rims? reddevil Tire & Wheel 5 03-09-2008 10:03 PM
Tire size for stock 16" wheels imisplacedmine Tire & Wheel 19 06-05-2006 03:18 PM
Widest tire size on stock 16" Bugeyes ?? choloman05 Tire & Wheel 4 03-22-2006 03:05 PM
Pics of Stock 16" rims with 225-50 tires?? rich22 Member's Car Gallery 13 03-28-2005 10:33 PM
Tire Size For Stock WRX Rims? InsaneAznKid Newbies & FAQs 13 05-26-2004 02:27 PM
