Old 01-19-2007, 09:44 PM   #1
TheKrazyAsian
Member#: 109613
05 STi
White W/Gold Wheels
Default ST/AP stage2 map help
Hey guys, I need some help with my ST.
I'm kinda a noob on the subject, but I need some help from you guys. I have a 05 WRX STi with the v.1 AP, ST and full exhaust (headers,up pipe, down pipe, and exhaust). I would like to run a stage 2 map but so far have been unsuccessful.
I used AP and loading the stage2 93oct map just as specified in the manual. After doing so I noticed no gains or changes in performance. I accellerated just as a stock STi. I am now connecting the ST to my vehicle and will attempt to load a stage 2 map from here. Where could I get a stage 2 map in .stb format? I have searched several forums with no luck. All I have found is .ptb files.
Please advise me in this matter, your help is greatly appreciated.
-Ed
Also, when trying to connect my laptop, ST would not recognize an ECU. Are there any tips for connectivity besides what the ST manual says?
TheKrazyAsian is online now   Reply With Quote
Old 01-21-2007, 07:15 PM   #2
TheKrazyAsian
Member#: 109613
05 STi
White W/Gold Wheels
doesn't anybody here use there street tuner that might be able to help??
Old 01-22-2007, 12:00 AM   #3
hondaeater69
Member#: 60324
ST base maps can be found here:
http://www.cobbforums.com/forums/showthread.php?t=31211
when connecting to the ECU, make sure you on the right port for your computer, and also make sure the OBDII cord is plugged in properly. I suggest downloading the ST stage 2 base map, flash it to your ECU via accessport, then connect with street tuner. when you open it up it should show that as the current map. it should be a noticeable difference from stock.
keep in mind you must connect the test mode connectors and any initialization plugs that may be required (not sure about the STi) when flashing a base map.
hondaeater69 is offline   Reply With Quote
Old 01-22-2007, 08:09 AM   #4
Wylan
Member#: 97854
2005 Impreza WRX STi
I recently installed a DP and flashed to ST stage 2, it takes a few flashes if you follow ST's directions, but not too hard.
As for the connection to the laptop for live tuning/Data logging, I had to reinstall my USB to serial drivers, ST wouldn't find the virtual COM port for some odd reason. Afterwards, it worked fine
Wylan is offline   Reply With Quote
Old 01-23-2007, 01:47 PM   #5
TheKrazyAsian
Member#: 109613
05 STi
White W/Gold Wheels
thanks i will have to try that tonight when i get out of school
Old 01-23-2007, 09:35 PM   #6
TheKrazyAsian
Member#: 109613
05 STi
White W/Gold Wheels
thanks to everyone all of your insight it helped to put me in the right direction so that i am able to go and tune now thanks agian
-Ed
2 quick Q's about ap. Stage2 91vs.93, and undeterminable maps? geist AccessPort 2 05-22-2007 09:01 AM
AP Stage2 93 octane map and Husky 94 gas... thejean Western Canada 13 04-04-2006 09:46 PM
91 or 94 oct on stage2 map? WReX4 General Community 6 01-08-2006 11:04 PM
Help again! flashing cel now with cobb dp and ap stage2 base map Chigliakus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-18-2004 10:33 PM
Question about different on utec stage3 and stage2 maps R.C.Y.K. Engine Management & Tuning 15 10-27-2004 01:25 AM
