Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 11-27-2001, 09:27 PM   #1
Sam Kaufman
Member#: 3135
98 2.5 rs
red
Question Blown Head Gasket! LONG thread
Well it finally happend. I heard the 98 2.5 is prone to this but was always hoping it was the other guy not me. I kept having an over heating problem and replaced the t-stat 2 times and I was still overheating. We tested for emissions in the radiator at work the first t-stat and we had no hydro carbons in the radiator. God news I thought. What I didn't really know is that it should have been tested with the old coolant in and while the car was at running temps. The t-stat didn't open and with the new coolant,we had no numbers indicating a blown headgasket.
I should have know all along because I had a gray sludge built up on the walls of th coolant resivior. I was thinking that I just really needed to flush the coolant. After doing the second t-sat,the car was fine for about a week. Then coming home,it overheated on me again. I limped back home and was able to drive fine with no over heating on my way to work. We tested for emissions in the radiator again and it was super blown. I had a reading of over 400 Hydro Carbons in my radiator. The alowable limit for H.C is 20 H.C. I had it towed to The local Subaru shop to have the warrenty work done. They told me it would be 3 weeks!!!!
I am a Service Manager at a shop and know that it doesn't take that long and i really don't think that their that busy.
Any way, the whole point of this thread is that we ALWAYS presure test and resurface the heads ANYTIME the come off.SUbaru told me that they hardly ever do this because it's not usally needed. What do you all think about that? And I heard a rumor that the replace the whole head with a newer version head for the 98my. Can anybody confirm or deni this? Your help would be great. Sorry for this huge thread,it's kind of a big issue for me.
Thanks for any help or info!
Sincerely,
Sam Kaufman
Sam Kaufman is offline   Reply With Quote
Old 11-27-2001, 09:48 PM   #2
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
There is no newer version of the '98 head. In '99 Subaru went to the Phase II head but it's not a simple replacement.
I would only surface a head if it was warped or eroded. The Subaru heads can only be surfaced .004", warp limit is .002". The heads don't crack but you could request at your own expense to have them pressure checked. If they choose not to and they still leak they are the ones that have to stand behind the work. What you really have to worry about is weather the cylinder split. It is fairly common when an EJ motor overheats for the cylinder to split where they are thinner for the case bolts. If it happened they will know as soon as it's back together and running, provided it was undetectable when apart (which also is common).
As for taking 3 weeks to do the work, it's maybe a days work. Check with another dealer, call SOA, whatever. It's a free market.
SubyTechMaster is offline   Reply With Quote
Old 11-27-2001, 09:54 PM   #3
Sam Kaufman
Member#: 3135
98 2.5 rs
red
The phase II is what I remember hearing about. I thought that they were replacing the 98 head with this. Your info helps lots! Thanks!
Blown head gaskets, warped heads and a piston melted to the cylinder wall Borjaq Warranty Issues & SOA Problems 13 05-22-2010 10:16 PM
Class Action Lawsuit Re: Blown Head Gaskets/ Cracked Heads/ Overheating oldblackbeard Legacy Forum 22 01-13-2005 12:18 AM
Well, I think it's a blown head gasket after all. Patrick Olsen New England Impreza Club Forum -- NESIC 13 03-05-2001 02:01 PM
Help me diagnose overheating/possible blown head gasket Patrick Olsen Normally Aspirated Powertrain 7 03-05-2001 12:05 AM
Blown RS Now with matching blown head gasket. 5252 Technical Forum Archive 66 09-18-2000 10:46 AM
