Old 01-24-2007, 01:45 PM   #1
Distinctive
Member#: 68122
2004 dbl u ar ex
VF34 w/white paint
Default RE 92's+plug=????
i recently put my stockers back on...and had a nail in a tire....
got it plugged at a local shop....
my question is will that plug hold up to the elements of driving in snow?
semi high speed cornering?
highway driving 70/90 mph?
never had a plug so i dont know any help ??
Distinctive is offline   Reply With Quote
Old 01-24-2007, 03:44 PM   #2
Distinctive
Member#: 68122
2004 dbl u ar ex
VF34 w/white paint
any one???
Old 01-24-2007, 05:21 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...relax......millions and millions of plugged tires out there
Old 01-24-2007, 05:36 PM   #4
Airborne_J
Member#: 93045
2004 FXT 5mt
2001 2.5 RS
Same thing happened with mine at the end of the winter season last year. Stored them over the summer and brought 'em back out a few months ago.
I've driven in rain/snow and at speeds over what you're describing and it's been just fine.
Suppose it depends on the plug job though. Also, keep your eye on the tire in question.
Airborne_J is offline   Reply With Quote
Old 01-24-2007, 07:21 PM   #5
evilwhitecar
Member#: 69380
2002 wrx sedan
aspen white
plugs are technically considered a temporary fix by most of the industry. and only used really in skid loader tires, bald tires and if you were a jerk to your tire tech or the tire place doesn't care. it will most likely leak eventually but i can't say really when it would happen. if you are really worried about it take it to a shop that does patch repair and have them fix it. patching repairs the inside of the tire which works a lot better. to think of it better what would you rather do. stick your finger in a leaking ship (plug) or weld a steel plate over the hole(patch). you can also use a plug/patch that combines both methods.
evilwhitecar is offline   Reply With Quote
Old 01-24-2007, 08:57 PM   #6
REX8
Member#: 24038
Originally Posted by evilwhitecar View Post
plugs are technically considered a temporary fix by most of the industry. and only used really in skid loader tires, bald tires and if you were a jerk to your tire tech or the tire place doesn't care. it will most likely leak eventually but i can't say really when it would happen. if you are really worried about it take it to a shop that does patch repair and have them fix it. patching repairs the inside of the tire which works a lot better. to think of it better what would you rather do. stick your finger in a leaking ship (plug) or weld a steel plate over the hole(patch). <---Thats a HORRIBLY INACCURATE ANALOGY ...you can also use a plug/patch that combines both methods.
It will most likely leak??? I'd bet my house a majority of plugs never leak.
Sure, a patch is better, and you shouldn't be doing things like tracking/etc. on a plug, but your shop must be bad at plugs if they all most likely leak...
That analogy is pretty bad man.... A plug is glued/cemented in JUST like a patch. (just a little different then "sticking a finger in vs. welding" don't you think?)
So, to be fair, you should have said this...
"would you rather WELD a plug into the side of a ship, or WELD a patch?" <--- See how much different that is???
Old 01-25-2007, 01:05 AM   #7
ScoobyBoy
Member#: 6418
itll be fine. ive got 2 plugs on the same tire, and have been in the snow. no issues. you dont have to worry about it.
ScoobyBoy is offline   Reply With Quote
Old 01-25-2007, 10:19 AM   #8
evilwhitecar
Member#: 69380
2002 wrx sedan
aspen white
i am sorry i over exaggerated....my bad i didn't know you don't like exagerations. two minor things. i said plugs leak eventually.... as it after a while. aka not immediatly. you have to consider that tires are driven under all different conditions and where the plug is located on the tire. second you don't use glue when you plug a tire. you drill out a larger hole in the tire then insert the plug with lube into the hole you just drilled. there is no gluing involved when you plug a tire. also when you drill said hole you can possibly damage the body cords in the tire which is why some plugs never seal properly. as for patch/plug combos you grind down the the inside of the tire. apply a cleaning fluid then a cement/glue then the plug/patch where the plug fills the hole and the patch seals around the hole for an air tight seal. if i left any more specifics out feel free to correct me since your tire knowlage is so much better than mine.....
Old 01-25-2007, 10:58 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
.......wrong----just plain WRONG
Old 01-25-2007, 02:00 PM   #10
nate.the.great
Member#: 72031
i've plugged two tires. the proper method is to use glue. neither have leaked in ~one year. my guess is that the tires will need to be replaced due to wear before they will ever leak.
offroad 4x4 guys have been reliably using plugs for years. if plugs will handle the abuse they put their tires through, i'm pretty sure they'll be ok on a street car.
nate.the.great is offline   Reply With Quote
Old 01-25-2007, 02:05 PM   #11
longboy
Member#: 138459
2001 Outback
My wife's soob has 2 or 3 plugs in one tire, that went in around 10k miles ago. The tires have reached 65k, and I'm finally ready to replace them. I have never had any problems with plugs.
longboy is offline   Reply With Quote
Old 01-25-2007, 09:54 PM   #12
ivwarrior
Member#: 100610
MBP
I've never seen anyone use glue when plugging a tire. The patch/plug combo is a much better option than just a crappy plug.
ivwarrior is offline   Reply With Quote
Old 01-26-2007, 02:53 AM   #13
nate.the.great
Member#: 72031
Who in the hell would not use cement when plugging a tire? The directions tell you to use cement.
I like the patch option better as well, but it's not always an option. A patch is done on the inside by a shop, so what happens when you're in the middle of nowhere and you get a nail in your tire? Plug it.
Old 01-26-2007, 10:27 AM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
Plugs have been around for at least 50 years, and likely a lot longer.
Plugs work if done right.
Plugs may not be the greatest, but they will get ya there.
Plugs in crappy tires are a match made in heaven
Plugs in re92's are a match made in heaven.
/thread
Old 01-26-2007, 10:40 AM   #15
evilwhitecar
Member#: 69380
2002 wrx sedan
aspen white
how do you use cement on a plug anyway? by using a plug you are repairing a tire from the outside. what are you doing to do put glue all over the outside???? it will wear off by the time you drive what? 5 miles
i do however agree that if a plug is your only option then use it. i just don't like it.
Old 01-26-2007, 10:59 AM   #16
nate.the.great
Member#: 72031
yes, 5 miles . you sure post a lot for someone who has no idea what he's talking about.
http://www.alpharubicon.com/bovstuff/tirepluguzi.htm
i use a bit more cement than that, but it's a great how-to guide. scotty is on point. i wouldn't use a plug in one of my MX's, but they have been great for winter tires and general all season tires.
Anyone need some RE-92's?? Bohanan @ work Texas Impreza Club Forum -- TXIC 26 02-11-2009 03:41 PM
my 2 videos on why NOT to play in your RE-92's ^jynx^ Tri-State Area Forum 8 05-16-2001 08:09 AM
Watch your RE 92's!!! RS22b Tri-State Area Forum 11 05-16-2001 12:56 AM
RE 92's jlyttle Brakes, Steering & Suspension 9 02-20-2001 03:08 PM
the almighy RE 92's thehanna Newbies & FAQs 6 12-01-2000 12:42 AM
