Old 01-24-2007, 06:59 PM   #1
leeswrx
Member#: 118295
05 STI
Default timing belt cover
Whats up guys, just had a quick question about the Timing Belt cover. I wanted to inspect it for cracks, missing teeth, ect. Besides the bolts on the front side of the cover(right side), is there thing I might need to do before removing these bolts. Any help would be greatful. Sorry for the noob question.
leeswrx is offline   Reply With Quote
Old 01-25-2007, 07:38 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Well if you want to remove it completely you have to remove the crank sprocket and the belts. And the fans are probably going to be in the way.
All the timing cover bolts are 10mm.
Tim Sanderson is offline   Reply With Quote
Old 01-28-2007, 03:38 PM   #3
eb1888
Member#: 115226
2005 wrx wagon
You can take off the driver's side for a look without removing the crank pulley bolt. After you take off some accessories. Timing belts more often stretch out of spec instead of fail by breaking.
eb1888 is offline   Reply With Quote
Old 01-29-2007, 12:46 AM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
What could you learn by removing the driver side cover? Other than seeing the belt on the sprocket, You can't see any other timing marks.
Timing belt cover and checking the timing belt Pinned Service & Maintenance 14 12-28-2015 12:09 AM
Help Please! Timing belt cutting into timing belt cover behind A/C idler pulley Kansai Subaru Service & Maintenance 14 10-23-2008 04:05 AM
Timing belt cover randomly BROKE and ate my T BELT ! IllNastyImpreza Service & Maintenance 9 03-09-2008 04:02 PM
ej257 timingbelt tensioner, belts+timing belt cover, wrx intake manifold+throttlebody White 2.5rs Private 'Wanted' Classifieds 1 07-19-2005 01:11 PM
Instructions for taking timing belt cover off to inpect the timing belt? scoobbee Service & Maintenance 3 05-09-2005 06:33 PM
