Old 01-24-2007, 07:11 PM   #1
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
Default 17X7...whats the wides i can go?
Just curious, but thats the widest tire i would be able to run on a 7" rim? is a 245 out of the question?
snowman4us is offline   Reply With Quote
Old 01-25-2007, 12:10 AM   #2
snovvbrdr
Member#: 121063
2006 WRX Stg. II
Steel Gray
yes 245/40's require at least an 8.0 rim 225/45's are about as wide as you could go on a 7 inch rim
snovvbrdr is offline   Reply With Quote
Old 01-25-2007, 12:41 AM   #3
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
i was thinking that i could run at least a 235...i have re070's on right now of an STi and they seem to fit pritty good, and looks like i can even run a bigger tire then that w/o a proble.
Old 01-25-2007, 11:11 AM   #4
REX8
Member#: 24038
Depends on the tires. 245 R comps on 7" wheels is pretty common. And 235 street tires on 7" wheels happens quite a lot too.
It really depends on whether this tire is being used for autox/track, or the street.
Old 01-25-2007, 11:18 AM   #5
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
this would be used for the track.
Old 01-26-2007, 10:16 AM   #6
kwan_1104
Member#: 127781
how about 235 on 7.5?
kwan_1104 is offline   Reply With Quote
Old 01-26-2007, 10:45 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
even MORE reason for using the correct wheel size.
225/45 is the widest ya should do on a 7"
...some of the autox d0000ds jam wide tires on skinny wheels due to the rules....it is NOT a good idea for most of us to try to follow those rules
Old 01-26-2007, 10:48 AM   #8
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
A random q.
But does anyone know if anyone has ever de-beated a tire from running to wide of a tire on a skinny rim? i can imagine that the side loads exerted on the sidewall can cause this if they are not stiff enoughf.
Old 01-26-2007, 11:09 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
A random q.
...ask in the motorsports forum
Whats the widest you can go with out rolling ur fenders? (zaksti) Tire & Wheel 13 07-13-2009 12:05 AM
Whats the widest I can go without rolling the fenders????? SubieAddiction Tire & Wheel 6 06-03-2008 12:52 PM
How Wide You Can Go ???!!! TAYFUN Member's Car Gallery 6 01-18-2008 11:12 AM
Are 16s the smallest you can go on a WRX mellow65 Tire & Wheel 4 02-27-2007 11:48 AM
What is the wides I can put on stock 16"? WRX_Sir Brakes, Steering & Suspension 5 03-07-2003 01:26 PM
