Old 01-24-2007, 10:24 PM   #1
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Cool Laile/Beatrush underpanel for BD/BG installed
Underbody aerodynamics is something I've been wanting to fiddle with for a while, and not too long ago while bouncing around various JDM parts websites I discovered that Laile makes an underpanel for the BD/BG (part #S561010). Their website says it's for turbo models, but I figured I could make it work - it's just aluminum, so if I had to trim it here or there it wouldn't be too hard.
Of course, nobody actually carries it here in the States, but I looked around for places that carried Laile/Beatrush parts and emailed some of them. I ended up going with www.cyberauto.com, which is actually a few different websites. They had the best combination of price and shipping time. I wasn't expecting it to appear until roughly the end of the month, but last Friday it showed up. Woohoo!
Today I put the car up on a lift and installed the part. As expected, there was some interference with the exhaust, but some "spacers" and longer bolts took care of that without any real issues. The panel is aluminum, as I said, probably about 1/8" thick (well, probably 3mm thick, since it's from Japan and most likely metric). At the front end it mounts to a plate that goes across the bottom of the radiator support:
On each side there's a little bracket that hangs down from the front bolt of the sway bar bushing mount:
The JDM cars have different bushings with flat brackets, whereas the USDM cars have those kinda weird humped brackets. So you can see the chassis end of the bracket got deformed when I tightened the nut down. No big deal, it's just aluminum.
At the rear of the underpanel there's a bracket that bolts to the cross-member, and that's where I had some interference issues. I figured there would be problems with the exhaust, as the underpanel is designed for a turbo car (with the exhaust above the cross-member). Sure enough, I was right:
Not the best pic, but with the bracket touching the OBX header, the flange was about 1/2" from the cross-member. So I bought a couple longer 8mm-1.25 x 40 flange head bolts to replace the original bolts, and then used a couple 10mm nuts on each one as spacers, like so (again, pardon the crappy pictures, not much light under the car so the flash was throwing lots of shadows):
With all the brackets in place, I bolted the underpanel on:
Butt dyno says the car is about 1/2sec quicker to 60, and I can hit 87mph at redline in 3rd instead of just 82mph before.
OK, just kidding. The next time I take the car to a track day I'll probably try running with and without it to see if there's any change in front end stability at speed. I can already see a couple things I want to fix. I'm not sure what the big hole in the middle of it is supposed to be for, since all it does is allow you to look at that plate that bolts across the cross-member. So I'll cover that over with a piece of sheet aluminum to make the bottom that much more smooth. Also, the plate slopes up at the front, which isn't really necessary and may actually be suboptimal, so I think I'll flatten it out. I'll probably end up attaching it with just a couple bolts to the bottom of the bumper (the black portion) where it overlaps. I'll also probably widen it at the front so that it extends all the way out to the edges of the bumper. Anyway, it's a good start, and although I could probably recreate something like this pretty easily using aluminum sheet from Home Depot, that stuff isn't as thick and sturdy as the Beatrush piece is, so I'm pretty happy with this.
Pat Olsen
'97 Legacy 2.5GT sedan
Patrick Olsen is online now   Reply With Quote
Old 01-24-2007, 10:25 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Sweeeet!
fibuz is offline   Reply With Quote
Old 01-24-2007, 10:54 PM   #3
b4u
Member#: 123043
1999 legacy 2.5GT
green
more beneficial for someone who rallys, but freakin pimp. i'd pay u to make me one!
b4u is offline   Reply With Quote
Old 01-24-2007, 11:44 PM   #4
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
It's probably there so you still have an accessible center jack point. Otherwise, you'd have to jack each side out at the sills.
It's a very nice looking piece of aluminum.
KD7000 is offline   Reply With Quote
Old 01-25-2007, 12:37 AM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
It's not intended to be a skidplate, it's an undertray to improve aero. Much like all the newer Subarus (and many, if not most, other new cars as well) have from the factory.
And, yes, KD7000, BIGSKYWRX pointed out that rather obvious purpose to me, too. My car is low enough that I generally jack from the sills anyway, but I would have figured out what the hole was for probably a few days after I covered it over.
Pat
Old 01-25-2007, 01:02 AM   #6
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Nice, looks like a clean piece of work.
Beats my 3/16" homemade skidplate in the looks dept. that's for sure
rougeben83 is offline   Reply With Quote
Old 01-25-2007, 03:11 AM   #7
that one legacy
Member#: 103665
sweet! how much was it + shipping?
that one legacy is offline   Reply With Quote
Old 01-25-2007, 08:33 AM   #8
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
I see the access hole for the oil drain, but what sort of access do you have to your oil filter ? To me the big reason why I have yet to install any form of "skid plate" or an under body "aero deflector" is do to this issue.
Any thoughts on remote mounting your oil filter somewhere more accessible so you don't have to drop this panel each and every time you perform an oil change ?
Jonathan is offline   Reply With Quote
Old 01-25-2007, 09:14 AM   #9
ten80
Member#: 53625
00 16' FXT
Looks nice, Pat!
I used to make skid plates and I can tell you that making something like this from scratch would be a PITA. Relocating the oil filter would be more of a challenge than removing the skid plate for every oil change. It's not that bad really, there's only 8 bolts and it might add 15 minutes. Oil changes should not be rushed anyways. They are a good time to check out the underside of the car and make sure that there are no leaks, torn CV boots, etc.
This plate would definately not work with a non turbo subaru that still had stock or Borla replica headers. The OBX headers give tons of clearance and you can fit most skid plates meant for turbo subarus (this applies to impreza, forester, and outback models also).
ten80 is offline   Reply With Quote
Old 01-25-2007, 02:06 PM   #10
flanders
Member#: 76382
2000 BH
BP Wannabe
Off Topic: What kind of oil filter is that?
flanders is offline   Reply With Quote
Old 01-25-2007, 02:20 PM   #11
that one legacy
Member#: 103665
looks like a Purolator PUREone, a pretty good filter for the money.
Old 01-25-2007, 07:41 PM   #12
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Yup, Purolator.
Old 01-25-2007, 08:23 PM   #13
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Hey Pat, did you get a bigger oil filter along with the oil cooler setup I see there?
Old 01-25-2007, 08:34 PM   #14
flanders
Member#: 76382
2000 BH
BP Wannabe
I was going to go way off topic and start mentioning all the interesting things seen under his car (like duct tape and brake vents) but I don't see anything indicating an oil cooler.
Ahh, maybe it's what looks like aluminum the filter is screwed to.
Where's Waldo?
Old 01-25-2007, 08:46 PM   #15
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
Nice work Pat!
I'm sure Pat will step in at some point, but IIRC he's using that sandwich adapter as a point to mount aftermarket oil pressure/temp sensors.
Oh, I would guess that hole under the center plate is because a lot of people (me included) use it as a jack point
Dan Cech is offline   Reply With Quote
Old 01-25-2007, 08:49 PM   #16
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
It looks like there are an fittings coming from that sandwich adaptor.... if you are running one;what oil cooler kit are you running I am looking for one for my car and am getting ideas.......
btw i like the underpanel alot, If i hadn't already bought sheet aircraft aluminum for mine i would buy that one.... good install
Russell Rogers is offline   Reply With Quote
Old 01-25-2007, 11:45 PM   #17
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
I would like to know this also
Looks like a pretty nice plate.
Wiscon_Mark is offline   Reply With Quote
Old 01-26-2007, 03:49 AM   #18
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Dan is correct - no oil cooler (yet). The sandwich adapter is just there so I could mount an oil pressure and temperature sending unit. I've since moved the temperature sending unit to the oil gallery at the top of the engine, so only the pressure sending unit is still in the sandwich adapter.
As for the duct tape on the bottom of the bumper, that's just some very ghetto radiator ducting to ensure air coming through the lower opening in the bumper is forced through the radiator and can't escape by passing under the radiator support. That was a precursor to doing some more "real" ducting, which this underpanel is the beginning of.
Cost was about $225 shipped. Basically, all of the vendors I emailed said the price of the underpanel was the same - about $180. A couple of the vendors I emailed said they could ship is sloooooow for about $45 or so, or fast for about $100. Cyberauto.com did it fast for $45, so that's who I went with. They said it would take 3-4 weeks, but in actuality it was only 10 or 12 days. Not too shabby.
Pat
Old 01-26-2007, 01:33 PM   #19
flanders
Member#: 76382
2000 BH
BP Wannabe
Mach III here in San Francisco apparently carries the Beatrush products.
I'll contact them and see what they have to say about getting this.
Old 01-26-2007, 09:25 PM   #20
dplacen
Member#: 117010
1997 Legacy GT
2006 Spec B #256
Nice Plate!
dplacen is online now   Reply With Quote
Old 01-28-2007, 02:15 AM   #21
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
It would appear the underpanel actually improves airflow. Doing some highway driving this afternoon/evening, my steady state temp at 75ish was about 83-84C on my Defi gauge pack. Previously, the temp would stabilize at about 86-87C on the highway. When I slowed down, the temp would go up to where it used to sit. Interesting...
Pat
Old 02-07-2007, 03:18 PM   #22
flanders
Member#: 76382
2000 BH
BP Wannabe
I talked to a shop that will do a group buy for this piece. If 10 people get in it will be $130 each not including shipping. The piece is large so shipping will probably put it around the price that Pat paid.
I am not affiliated with this shop, just trying to help you guys out.
Send me a PM if you are interested.
WTB: Beatrush underpanel for 2008 WRX Zulu- Private 'Wanted' Classifieds 0 04-02-2010 05:16 PM
heated mirror for BD/BG? etam Legacy Forum 17 01-05-2004 07:20 PM
who needs skidplates for BD/BG etam Legacy Forum 1 11-20-2003 01:16 AM
Whiteline rear strut bar for BD/ BG Legacy BrokenCrank Private 'For Sale' Classifieds 4 10-07-2003 05:53 PM
Who wants JSM clear side markers for BD/BG Legacy? yuji Legacy Forum 49 12-12-2001 08:20 PM
