Old 01-24-2007, 11:28 PM   #1
BE-Fresh
Member#: 126221
'07 Spec.B
Default Impreza=Legacy?
Can someone tell me exactly what is compatible between the Impreza/WRX and the BE Legacy??
BE-Fresh is offline   Reply With Quote
Old 01-25-2007, 01:05 AM   #2
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Most suspension pieces in the front. Anything that can bolt on to the NA EJ25 motor (check if you have PhaseI or Phase II) will work or will work with a little modification.
rear...ugh rear diff protector and that's IF you don't have an aftermarket exhaust (for me at least...I still need to cut a piece of mine off to fit).
rougeben83 is offline   Reply With Quote
Old 01-25-2007, 03:00 AM   #3
jamal
Member#: 71875
98 Legacy GT
my wheels fit
New impreza and BD have much more in common. The BE is a generation ahead and the 05+ is two. Anyway the big chassis differences are in the rear suspension. 00+ Legacies have a multilink setup where the Impreza still has the macphearson coilover strut + lateral links. The driveline, brakes, wheels, and I think front suspension parts are still compatible though.
Either way, the whole "exactly what is compatible" question isn't easily answerable. Is there something in particular you had in mind?
jamal is offline   Reply With Quote
Old 01-25-2007, 09:17 AM   #4
ten80
Member#: 53625
00 EJ205 LGT-4SALE
^ditto. The list of compatible/incompatible parts is too long to list! Check out my swap thread for more info about driveline and such. I swapped an 03 WRX driveline iinto my 00 BE legacy.
ten80 is offline   Reply With Quote
Old 01-25-2007, 11:17 AM   #5
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
and add a few hundred lbs...
the BE/BH models are very heavy
iamrazor is offline   Reply With Quote
Old 01-25-2007, 12:25 PM   #6
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Only a few hundred?
Wiscon_Mark is offline   Reply With Quote
Old 01-25-2007, 12:37 PM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
L's start at 3200lbs + change, GT's 3300lbs+, Beaner wagons can go to 3400lbs.+
The "big change in weight" isn't that big of a difference compared to the older Legacies...and considering that the Impreza's, WRX's, and STi's are all pushing close to 3200lbs-3300lbs as well...it's not really exact to call the BE/BH cars pigs.
Old 01-25-2007, 01:06 PM   #8
Subidy
Member#: 64259
07 impreza STI base weight of 3,351
07 legacy sedan outback LL bean weight of 3,570
07 legacy wagon outback LL bean weight of 3,600
not a huge difference.
Subidy is offline   Reply With Quote
Old 01-25-2007, 01:09 PM   #9
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
Originally Posted by Wiscon_Mark View Post
Only a few hundred?
ok, like 5
Old 01-25-2007, 03:13 PM   #10
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
So that's what, four sorority girls, or three and a lot of beer?
There is a lot of Impreza stuff that lines up nicely, but some compatibility issues exist, like the way the exhaust lines up around the converter for headers, or spring perches in the front suspension. As stated above, it's best to be more specific... or even see what the rest of us have done in other threads.
LetItSnow is offline   Reply With Quote
Old 01-25-2007, 05:33 PM   #11
rougeben83
Member#: 115154
2005 Outback XT
White on grey
07 are the BL/BP models though...
Old 01-25-2007, 05:44 PM   #12
flanders
Member#: 76382
2000 BH
BP Wannabe
Seats will transfer with no modification. Apparently the seat height is higher.
Steering wheel is easy.
Recently several BE/BH people have gone with used STI axle backs (exhaust). I will be doing this myself. Modification is necessary.
Pulleys are the same but probably not most other engine pieces due to lack of turbo.
Suspension:
End links are the same.
Steering rack bushings should be the same. (whiteline part number is KSR202 I think).
Sway bars, springs and struts will not work.
I'm pretty sure strut tower bars will not work.
Brake parts are different but you can swap but there is little advantage.
flanders is offline   Reply With Quote
Old 01-25-2007, 08:18 PM   #13
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Strut tower bar will work, sorry only pic I have. It's a generic one off ebay, for a GC impreza
ALK will work (that's going on next, maybe...)
Steering rack bushings work (I have them)
Front endlinks and swaybar bushings work (ditto)
Front tophats work
I never got confirmation on the swaybar though, I didn't bother checking mine vs. a pic.
Brakes work (rears not needed), front brake lines work.
Oh yeah, headers, catalyst section will work. Cams will work, panel filter will work, same procedure to put wrx injectors will work, and *some* GC skidplates will work if you drill a couple of extra holes in the front.
Old 01-25-2007, 08:19 PM   #14
BE-Fresh
Member#: 126221
'07 Spec.B
Thanks alot guys, I appreciate it. I was just looking into some aftermarket parts for the BE, and just wanted to know since both legacies and impreza's have the same engine, and I've heard some people say that suspension parts would fit also. I was mainly looking into just lowering springs for now, not doing too much until warm weather comes back
Old 01-25-2007, 11:46 PM   #15
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
and those pretty 2004 sti wheels will fit!!! Oh how I love the look of my 2001 legacy outback with the gold sti 17's all around...
janikphoto is offline   Reply With Quote
Old 01-26-2007, 01:54 AM   #16
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Springs don't work because of the Legacy rear suspension. I think ion makes springs for your car though.
Old 01-26-2007, 09:05 AM   #17
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
as does H&R
Old 01-26-2007, 10:08 AM   #18
subi444
Member#: 138563
this might be the wrong place for this but do oyu guys know if the interiors of the 2 cars are similar? i am looking to put the three gauges up my a pillar but i haven't found anyone that make one for the legacy...would the impreza one work?
subi444 is offline   Reply With Quote
Old 01-26-2007, 11:06 AM   #19
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
It will on the BD/BK/BG, but I'm not sure about the BE/BH
Old 01-26-2007, 12:14 PM   #20
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Forgot to add, we use the same gearbox as the GC RS, so clutch, rear diff will work as well.
02-03 front brakes is what BE/BH's use, so don't go off buying 03+ pads.
WR-Limited 2005 Impreza, Legacy, and Legacy Wagon wrx_sti_ver4 News & Rumors 2 08-19-2005 12:01 AM
Vented rear disc brake "kit" from turbo legacy- fits any Impreza/Legacy/Forester ciper Private 'For Sale' Classifieds 7 09-17-2003 02:38 PM
Legacy...Impreza...Legacy...Impreza...Integra... SubieKidTK Legacy Forum 13 07-09-2001 05:57 AM
New Impreza front brakes compared to old Impreza/Legacy Patrick Olsen Brakes, Steering & Suspension 3 03-25-2001 07:53 AM
Impreza legacy cross over question slide Legacy Forum 5 03-05-2001 04:56 PM
