Old 01-25-2007, 12:04 AM   #1
Engmus
Member#: 115645
Default Need quick help with Rear diff
Ok so im changing the fluid on my rear diff, its on perfectly level ground, not jacked up or anything, how can i tell when its full? When oil starts to run OUT of the fill hole?
should I stick my finger through the fill hole and see if I can "touch" the oil?
How do you guys range this?
04 STi
Engmus is offline   Reply With Quote
Old 01-25-2007, 12:47 AM   #2
turboL
Member#: 111735
96 Legacy2.0GTSOLD
Bimmer Tech
yup, you fill it till it isnt gona fill anymore.
turboL is offline   Reply With Quote
Old 01-25-2007, 01:18 AM   #3
FD777
Member#: 84820
2005 WRX Sedan
Crystal Gray
I fill until the oil starts to overflow.
According to my manual, the STi uses 1.0-1.2 qts.
FD777 is offline   Reply With Quote
Need some help with rear diff fluid change Blazin New England Impreza Club Forum -- NESIC 17 07-17-2006 02:54 PM
help with rear diff????? 5.0Ranger Transmission (AT/MT) & Driveline 0 04-16-2006 02:50 PM
Help with rear diff 12.9$500rex Transmission (AT/MT) & Driveline 5 04-01-2006 01:46 AM
Need Quick Help with removing rear rotor (it's stuck) njpreppy Brakes, Steering & Suspension 5 07-22-2004 04:02 PM
need quick help with alternator belt.. JB1 Southern California Impreza Club Forum -- SCIC 0 12-26-2003 02:34 AM
