Old 01-25-2007, 11:33 AM   #1
djcttb
Member#: 33522
07 - the next
big thing ;)
Default coilovers compatible with legacy BG5....?
I was told tein CS has a set of coilovers for the bg5 chasis but I've searched with no luck. any other companies make coilovers for the bg5 or am I just SOL?
thx guys
djcttb is offline   Reply With Quote
Old 01-25-2007, 01:51 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Ground Control fits everything.
Old 01-25-2007, 02:10 PM   #3
djcttb
Member#: 33522
07 - the next
big thing ;)
after researching from my slow ass cell phone, I see that 02-03 wrx wagon coilovers will fit on a 95 legacy wagon (going by the wagon to wagon theory). I'm looking into the omnis or some h&r (like I had on my wrx)... but when searching for them it doesn't seem wagon specific. just something along the lines of (02-03 wrx coilovers). would a full coilover setup from an 02-03 wrx be a complete bolt on swap? if not, what else would I need?
as far as gc coils, can you specify your statement more? I've personally never had a suspension combo using different springs and struts... its usually a full coilover. which gc fits the bg5?
ryan
Old 01-25-2007, 06:33 PM   #4
djcttb
Member#: 33522
07 - the next
big thing ;)
er.. bump?
Old 01-25-2007, 07:40 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Ground Control sleeves should fit just fine on any struts you want. I'm using them with stock struts with Koni inserts, and I know I've seen them paired up with KYB AGXs, too.
Pat
Old 01-25-2007, 08:14 PM   #6
rougeben83
Member#: 115154
2005 Outback XT
White on grey
You can try coilovers that fit BD's. You can order the rear with a slightly stiffer spring set from the factory.
Also... Outback w/ GC/AGX's.
rougeben83 is offline   Reply With Quote
Old 01-28-2007, 11:45 AM   #7
djcttb
Member#: 33522
07 - the next
big thing ;)
GC for wrx or are they legacy specific?
Old 01-28-2007, 05:11 PM   #8
MeanEditor
Member#: 123139
1993 Turbo L Wagon
RED
Any Impreza suspension up to 2005 not including STI will fit your car. In the last issue of Subiesport we put coilovers from a 2005 RS on our 97 LGT.
Or are you looking at putting coilover sleeves on your struts? I would think this would work as coil sleeves seem to be pretty universal in application.
MeanEditor is offline   Reply With Quote
Old 01-28-2007, 05:19 PM   #9
rougeben83
Member#: 115154
2005 Outback XT
White on grey
GC coilover sleeves are pretty universal. It comes with a bunch of spacers for you to custom fit the spring perch and spring onto whatever strut you are choosing to run.
With the stiff spring rates they come with though, I wouldn't try this with a stock strut (hence AGX's), or GR2's. They would just wear out much too quickly.
Old 01-28-2007, 08:04 PM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I see people say this all too often, and I have no idea where this idea comes from, because there is absolutely ZERO truth to it. Yes, spring rates that are too high are bad, but you can spec whatever springs you want with the GC sleeves. There is no "standard" setup when you order from GC - you look at the dozens of different spring rates that are available and you pick what you want. I've run 225f/200r, 315f/280r, and 375f/350r over the past few years. There are springs that are even softer than the 200# springs that I've run, and there are springs even firmer than the 375# springs I've got now.
Pat
Old 02-26-2007, 01:45 AM   #11
kmin
Member#: 28968
1997 BG Outback Ltd
black riding on MR.
Megan Racing coilovers for the '02-'03 WRXes will bolt up just fine (might want to swap the front L and R tophats, or whatever they're called, for better alignment). mranlet and I both run this setup (he's selling his right now).
kmin is offline   Reply With Quote
JDM LEGACY BG5 TEIN COILOVERS fit BD? co2cool926 Brakes, Steering & Suspension 0 07-08-2008 09:27 PM
Is the legacy GT 5spd Auto compatible with the WRX? Silhouette_WRX Subaru Conversions 2 02-18-2007 04:30 PM
Forged BBS 16" Wheels jdm Legacy BG5 vdubster79 Private 'For Sale' Classifieds 22 01-30-2006 04:55 PM
Jdm Subaru Legacy Bg5 94-98 Momo Steering Wheel BoardRider Legacy Forum 6 10-13-2005 06:35 PM
is new AC system compatible with MY97 Legacy? etam Legacy Forum 2 05-10-2005 04:37 PM
